96 Runner Trailer harness "module" #413479 03/07/04 11:25 PM
Can anybody tell me where the trailer harness "module" is located on a 96 Runner? It's the stock hitch and harness.
Thanks in advance.
NL5
Re: 96 Runner Trailer harness "module" #413480 03/08/04 02:30 PM
probably behind the drivers brake light assy. If not follow the wires from the connector near the hitch. It usually leads up behind the tail lights through a grommet in the body.
Re: 96 Runner Trailer harness "module" #413481 03/08/04 04:44 PM
nope...already checked there. It goes up into the truck on the passenger side side about a foot behing the bumber and 2 feet from the side of the truck, and I cant trace it past there.
Re: 96 Runner Trailer harness "module" #413482 03/08/04 08:26 PM
I work tomorrow, I'll look at on of the wiring diagrams and let you know unless someone else answers you first..
Re: 96 Runner Trailer harness "module" #413483 03/08/04 09:51 PM
Cool......THANK YOU!
Re: 96 Runner Trailer harness "module" #413484 03/09/04 03:20 PM
If a trailer harness has been installed at the port or dealer you will see the wire clearly under the truck leading to the trailer hitch. If you do not see one, you don't have one.
None of these were installed at the factory by Toyota. They were either installed at the port, or at the dealer, or not at all.
Gadget
www.GadgetOnline.com
Re: 96 Runner Trailer harness "module" #413485 03/09/04 04:21 PM
I can see the harness, I just can't find the "module" that converts it to a 4 wire system. The harness says "Toyota" on it, so I thought it was factory.
Re: 96 Runner Trailer harness "module" #413486 03/11/04 08:35 PM
Rob_dup2 Offline
I had to replace this module in my '97 I am not sure if your truck is identicle to mine but my 'module' was on the passenger side in the back. It would be right before that 'cubby hole'. I needed to remove that entire pannel which goes up and around the window. (well ok loosen it up)Don't forget to remove the panel on the floor first. I then took a puddy knife to remove it and bring it out before cutting the wires and splicing the new module in. Hopefully this might help..
Re: 96 Runner Trailer harness "module" #413487 03/13/04 04:23 AM
Sherpa Offline
When I purchased Sherpa, I didn't think my module was working properly, so they replaced it with what was apparently a better module. I thought the mechanic replaced the module from inside the back on the driver's side.
Does this module allow for electric brakes?
PHP: 7.4.33 Page Time: 0.022s Queries: 14 (0.018s) Memory: 0.6099 MB (Peak: 0.6925 MB) Data Comp: Off Server Time: 2026-11-18 21:35:56 UTC
