Air Filter
#414536
03/09/04 06:55 AM
Been lookin at some options. Two questions...
1)Is it true K&N filters give you better gas mileage?
2) What custom filters are on your trucks and reviews of them.
Thanks
Re: Air Filter
#414537
03/10/04 02:23 AM
From what I understand people using the K&N in the toyota have not seen any benefits from it, except that it is cleanable. Personally I use the Amsoil air filter. It is an oiled filter and can be washed every so often. Do some research on it on the forum, its been talked about several times.
Re: Air Filter
#414538
03/11/04 08:44 AM
Hit up Gadget, he's dynoed everything and has all the results you will need for your question. www.gadgetonline.com
Re: Air Filter
[Re: humanoid]
#414539
03/12/04 12:29 AM
I had the Amsoil filter. Just is a pain to clean and re-oil. Know what, the OEMs work just fine.
2001 SR5 4Runner 4x4
Performance considerations...........
[Re: Dbryan22]
#414540
03/12/04 03:59 AM
NHRA Drag teams spend 100's of thousands of dollars to shave a tenth or so off their 1/4 mile times. Right???? You would never "feel" a change in your vehicle from an air filter. It's one piece of a puzzle which would include Airbox mods and a aftermarket exhaust system. One with out the other is only 1/2 the puzzle. You'll be moving more air through your oil coated filter than you would through a paper filter. Fact....more air equals more horsepower. Blowers an superchargers do just that . Jamming huge amounts of air through the engine. One little filter will only do so much. Kenny s>
Re: Performance considerations...........
#414541
03/12/04 04:26 AM
However, the results from simply opening up the intake are marginal, particularly on the 3.4. The real benefit is in increased fuel economy. I estimate a realized 6% overall gain in MPG. The caveat is that I use the "egg on the accelerator pedal" method of acceleration.
HP gains are imperceptible with any airflow mod on the 3.4 until you go SC. So many people have tried to prove that noticeable gains in performance are realized, only Gadget (that I am aware of) has proven by testing and objective evidence.
It sounds cool though.
Mike
A balancing act
#414542
03/12/04 04:28 AM
The perfect air filter would trap 100% of debris but it would let no air through. Today's filters use the oil and larger openings to maximize air flow and debris removal.
Don't forget air temerature. Cooler air makes for more horsepower. I believe they even make some sort of ice cooler for air intakes to create the cool air needed for peak performance.
Modifications to the average vehicle require many mods that will equal increased performance and fuel economy. But in small amounts. Don't expect to lifting the front end with a air filter mod. Kenny S
AZRAin....like I said, air mods are only as good as your exhaust sytem. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: A balancing act
#414543
03/12/04 05:57 PM
Re: A balancing act
#414544
03/12/04 10:32 PM
i jsut got my amsoil filter and was curious whether i should blot some of the excess oil off before putting it in (like with a cleaning ) so i dont doul up the MAF
Re: A balancing act
#414545
03/16/04 03:56 AM
i jsut got my amsoil filter and was curious whether i should blot some of the excess oil off before putting it in (like with a cleaning ) so i dont doul up the MAF Yes, just take two paper towels and sandwich the filter between them as you squeeze it between your hands together.
Milan _ _ _ _ _ _ __ _ _ _ _ _ _ Support our troops!
'98 4R Limited '82 Toy 4.3 TBI sold
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6204 MB (Peak: 0.7224 MB) Data Comp: Off Server Time: 2026-06-10 15:37:41 UTCValid HTML 5 and Valid CSS
