Possible Longer KYB's for Gen II's
#415943
03/11/04 05:49 PM
Did some searching in KYB's catalog the other day and found the following info for all you Gen II owners -
Stock Front - KG54302 Rear - KG54303 Extended length - 17.99, compressed length - 11.57, stroke - 6.42 top mount - 3/8" stem, bottom mount - 16mm x38mm sleeve
Extended rear shock - 343161 Extended length - 20.28, compressed length - 12.01, stroke - 8.27 top mount - 3/8" stem, bottom mount - 12.8mm x38mm sleeve
The only two catches I see is 1) need to extend the bump stop by 1/2" to prevent bottoming out shock, and 2) have to replace the bottom sleeve with the 16mm x 38mm one. I believe this should be possible.
Lee '94 LS, 3.0 V6, Auto, completely stock
Re: Possible Longer KYB's for Gen II's
[Re: Lee N]
#415944
07/26/08 01:04 AM
I spoke with KYB's tech over the phone regarding the 343161 and he said they are not valved correctly. He said they would need to be replaced in a week because they provide about 1/3 of the dampening neccessary for the Montero. I read another post about the Montero's rear shock angle that requires more dampening than a vehicle of comparable weight. My 2c.
98 Montero
[Re: nathanmakino]
#415945
07/26/08 03:19 AM
Gotta be close to a record for resurrection of a thread <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: hazy_daze]
#415946
07/26/08 04:12 AM
Holy Rip Van Winkle Batman... And the guy just joined with this post. Now that's what I call using the Search function! <img src="/forums/images/graemlins/patriot.gif" alt="" />
[Re: hazy_daze]
#415947
07/26/08 04:13 AM
Gotta be close to a record for resurrection of a thread <img src="/forums/images/graemlins/kewl.gif" alt="" /> Phew! the dust made me sneeze <img src="/forums/images/graemlins/lol.gif" alt="" /> Welcome to the forum. <img src="/forums/images/graemlins/cheers.gif" alt="" />
