Rear end noise #415979 03/11/04 06:52 PM
tacomajsc Offline OP
I have a 98 2.7 4x4 standard cab. I have noticed the noise for a while now and can't get rid of it. It only does it everyonce in a while and usually when i am not giving it gas. I have lifted my truck since the problem started. I have put diff tires and wheels, new shocks, and add-a-leafs under it and still sounds the same. Is their bearings in the axle i might need to check. I am getting ready to make a trip in it tomorrow to FL and back. I hope there is nothing serious wrong with it. <img src="/forums/images/graemlins/confused.gif" alt="" />
My signature has been removed.
Re: Rear end noise [Re: tacomajsc] #415980 03/11/04 08:09 PM
is it like a whining? or a metal on metal grinding or what? or a clunk?
Re: Rear end noise #415981 03/11/04 08:17 PM
Like a whining, i can't really explain it. I does have a metal sound to it.
Re: Rear end noise [Re: tacomajsc] #415982 03/12/04 12:18 AM
john_luttrell Offline
Has lubing the drive shaft lube points made any difference? Check the oil level in the rear end, it could be low or be contaminated with water which would make it appear milky in color. A noise like you described is usually pinion bearing or ring and pinion ingagement related. I have seen some be noisy for years with no problems, and others make noise for a few days then crap out on ya.
John Luttrell
2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.010s) Memory: 0.5941 MB (Peak: 0.6515 MB) Data Comp: Off Server Time: 2026-11-01 19:39:03 UTC
