Fishplating the Trailing Arms... #417021 03/13/04 07:59 AM
A
AcidophilusRex Offline OP
I'm probably going to be doing a rear spring lift in conjunction with new tires, and I figure I otter do the fishplate thing while I'm at it.
Can the fishplating be safely done with the arms still in the vehicle, or should they be removed for the procedure? My big concern is that if they're still on the vehicle and the person doing the welding uses an arc welder, it could potentially toast the electronics.
Re: Fishplating the Trailing Arms... [Re: AcidophilusRex] #417022 03/13/04 08:11 AM
LandRaider Offline
Nah. As long as they don't ground it on the posisitive side of the system!!! haha As long as they put the ground on the frame, it will be fine. I personally woudl remove them to make sure I got the best welds possible there. Get emmmHOT!! Megablast weld
Re: Fishplating the Trailing Arms... [Re: AcidophilusRex] #417023 03/13/04 01:09 PM
OKRED Offline
Keep in mind here that the welding current runs between the positive and negative leads, the path of least resistance and all that. I generally keep the ground very close to the actual work, makes a better weld and should prevent any current running through out the truck.
Chris
A brand spankin new 1973 series 3 Landy
OLIVE DRAB SWB, TURBO, IN ABOUT 36 PIECES
89 TROOPER, RESCUED FROM THE YARDS. (Down again)
05 TACOMA CREW SHORTY.
Re: Fishplating the Trailing Arms... [Re: OKRED] #417024 03/13/04 03:31 PM
DougH Offline
Mitsubishi Forum Moderator
I have welded on my truck before no problem. I just unplug the ecu to be safe.
DougH
1995 SR - RIP
1993 RS - RIP
Re: Fishplating the Trailing Arms... [Re: DougH] #417025 03/14/04 06:11 AM
IIRC, the factory manual advises removing connections to the alternator, the battery and the computer before doing any welding on the vehicle...
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6042 MB (Peak: 0.6691 MB) Data Comp: Off Server Time: 2026-11-04 04:10:54 UTC
