How big of a tire on a '93 Runner? #419016 03/17/04 02:52 AM
CORunner93 Offline OP
How big of a tire can you get on a 1993 4Runner with no lift in it....just stock suspension?
And....
How big of a tire can you get on it with a 2" body lift?
(the suspenion is getting completely redone...to stock height)
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
Re: How big of a tire on a '93 Runner? [Re: CORunner93] #419017 03/17/04 03:05 AM
My 31x10.5's would barley rub when my wheels were fully turned on my '95 4Runner. After a 3" body lift I cleared 33x12.5's with less rubbing as the 31's at stock height. You could always crank up the T-bars and get a small spacer in the rear and probably fit 33's with a 2" body lift.
Re: How big of a tire on a '93 Runner? #419018 03/17/04 03:11 AM
4Crawler Offline
Yep, 31x10.50 as-is or 32x11.50 if you do a little work trimming the front fender, assuming stock wheels.
1" - 2" body lift is usually plenty to run to fit 33s.
Re: How big of a tire on a '93 Runner? #419019 03/17/04 03:18 AM
J94_4runner Offline
my 94 came stock with 31x10.50x15. If you remove the running boards and mud flaps, set your fender to rim Tbar setting to 14"ish and get some 1.5" HD springs you can get away with 33's. I'm running 35x12.50x15 Dunlop Mud Rover's on my 94 with 3" body lift, rear 1.5" (levelers) and cranked Tbars to about 14.5" setting. only rub upfront with full lock turns. also, becareful b/c some tires are different "actual" sizes. My 35" Mud rovers only measure 33.8". my Goodyear wranglers (stock size and wheels) 31x10.50x15's measured 29.5". So some manufactures make different size tires even though they are all the same "size". You can do 33" BFG's or Dunlops with ease.
www.celicasupra.com
Re: How big of a tire on a '93 Runner? [Re: J94_4runner] #419020 03/17/04 03:52 AM
SHAD Offline
I was running 33's with just rear lift coils and a torsion crank and some creative trimming. It would still rub until I bent some metal out of the way it also depends on the backspacing you are running as well. I am running a 1.4" BL now no rubbing issues at all. I am still trying to get my crap running though.
86 Toyota 4 runner
35x12.5 BFG MT's, 4.56's XRC8 winch
My cardomain page
Re: How big of a tire on a '93 Runner? [Re: CORunner93] #419021 03/17/04 05:05 AM
jcssurf Offline
i run 32x11.50 on 15x7s with 3.75 backspace...i did a little trimming of the valance and fender lining (20 minutes) and can only make them rub at almost full lock and compression.
on stock wheels you should have little trouble clearing 32s
with the body lift, 33x12.50 on 15x8 should work nicely
90 pickup, 22RE, stiff-ass Ranchos, 2.25 catback, 4:1 header, conical intake, 15x7 ICW alloys, 32x11.50 Dunlop Mud Rovers, 4.56s w/v6 rear
-Farm truck until school is done...then plans
2000 Honda CRV EX 5 speed
-Driver
Re: How big of a tire on a '93 Runner? [Re: jcssurf] #419022 03/17/04 07:10 AM
'90 4runner - 32x11.5 BFG A/T's on on stock alloys no lift. they rub a bit and there is a loud clunk! when i crank the wheels all the way(?) Anybody know what the heck THAT is?? Want to put 1.5" lift in - Downey HD coil springs and crank my Tbars. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: How big of a tire on a '93 Runner? #419023 03/17/04 02:06 PM
I have 33/9.5's on stock with a minor t-bar tweek. I like the larger diameter tire, just wish they were wider. The tall skinny's don't rub at all. But then again, they are tall skinny's. Wish they were wider...did I mention I wish they were wider.
Re: How big of a tire on a '93 Runner? #419024 03/17/04 04:56 PM
jcssurf Offline
That's your steering stop(s) grinding...the plastic wears through fast and you get metal on metal
scares my passengers...i like <img src="/forums/images/graemlins/smile.gif" alt="" />
-Driver
Re: How big of a tire on a '93 Runner? #419025 03/17/04 05:19 PM
4Crawler Offline
You can upgrade to the 33x10.50 tires for something wider:
9.50 vs. 10.50 tires
9.50 MT left and 10.50 AT right:
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6367 MB (Peak: 0.7557 MB) Data Comp: Off Server Time: 2026-06-18 07:50:24 UTC
