Re: Oh no, jeep parts!! (Or, my new drivetrain...)
[Re: houlster]
#422766
12/20/04 11:13 PM
Good backtracking, Sherlock. <img src="/forums/images/graemlins/pfft.gif" alt="" /> Full manual control has its risks, eh? Are you going to provide manual gates for the shifter, or enforce shifting order with coded logic?
Nice patch, fabbing up a retainer strap. <img src="/forums/images/graemlins/kewl.gif" alt="" />
So did you swap in the replacement or just fix this one and call it good?
Randii
[Re: randii]
#422767
12/21/04 03:50 AM
Isuzu Moderator
I'm keeping the original tranny in. It's got fewer miles on it and the case is a lot cleaner and corrosion free on the outside. I hope to get the electronics for the shifter working this time around, so the logic will do the lockout. --Dan
[Re: houlster]
#422768
07/20/07 11:36 PM
Did you ever get the Volvo shifter to work ?
We've a few AMC builders that would enjoy knowing the 'ins' and 'outs' .
thanks -
[Re: milnersXcoupe]
#422769
07/21/07 08:46 PM
talk about digging out old threads
94 Rodeo sas'd front dana 44(coil sprung), dual transfer cases (isuzu), tera lows, custom bumpers, winch, arb lockers[url= [url=http://community.webshots.com/user/94rodeo] [url=http://community.webshots.com/user/94rodeo[/url] http://community.webshots.com/user/94rodeo[/url]
[Re: 94rodeo]
#422770
07/21/07 09:00 PM
Isuzu Moderator
talk about digging out old threads For once someone used the search function... we need to praise that kind of action, not mock it. <img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Sean Strawmyer Back and ready to rock...... crawl. From Indiana or surrounding states and interested in wheelin'? Check out www.mwior.com
[Re: milnersXcoupe]
#422771
07/21/07 10:19 PM
Isuzu Moderator
Not for gear selection, just P -> D. I'm still using the rotary switch. The problem is it works good enough I don't get motivated to re-do it. Too many other things to spend the time on. Really, the biggest problem with the Volvo shifter is that it only goes to D. You can't shift to '3' or '2'. The problem with that is you don't get compression braking in 'D' unless you're in 3rd gear. Kinda sucks for offroad. Shift down to '3' and you get braking in 2nd, shift to '2' and you get it in first. This part isn't electronic. You need to move the shift selector in the tranny. I do think it could be made to work electronically with a servo on the selector along with the floor shifter. The shifter (the Volvo would work good this way) would select P->D, then the servo would move the selector in the tranny to the D/3/2 positions as you shift the tranny so you can always maintain compression braking. It's one of those things I get fired up about once in a while, but then bigger things take over. --Dan
[Re: houlster]
#422772
07/22/07 02:34 AM
Thanks Dan - Our www.amc-list.com members want to run the aisin AW4 / RWD transmissions for driver / street AMC cars behind 4.0 > 360 - 401 4V V8s - a shifter that will allow full shifting 1-4 is the Topic. List Moderator Frank S. has built a '64 Rambler Wagon with a 4.0/ Aisin / a rotory selector - early 'E' jag IRs. I've purchased an A-761E 2004 LS430 Lexus 6spd with converter off eBay - has a black box on the side - going into a Gremlin. Engine: '05-'06 Toyota 4.7
