Re: Front Driveshaft Recommendation [Re: 4Crawler] #424457 03/31/04 05:51 PM
DirtyHarry Offline
Toyota Moderator
I bought my shafts about a year ago and Jess charged me $289 to rework the my front CV and add longer splines. Chris if you really want to save money though I would go with an inexpensive option now, such as a square driveshaft, and then get the high dollar stuff when you add the second transfer case. I say this for two reasons. One, obviously you don't want to spend the money twice. But secondly, with the lift that you have and only a single transfer case, I would expect the CV to bind at full passenger side droop, even with the CV opened up. The last thing you want is to wreck your expensive new parts.
Do you really drive at highway speeds in 4WD a lot? <img src="/forums/images/graemlins/confused.gif" alt="" /> When I lived out there if I was in 4WD I was usually going a LOT slower, but that was in a short wheelbase Jeep too.
Re: Front Driveshaft Recommendation [Re: DirtyHarry] #424458 03/31/04 06:23 PM
ad54runner Offline OP
I don't know what you would classify as a lot, but I would say at least a couple dozen times per winter. Anytime I want to go over Eisenhower in the winter I typically have to use 4 hi at highway speed. I am talking the 45-60 mph range, not like 75 or anything.
The other thing I need to consider is that I now have an automatic locker up front. I have never driven with a front locker and for all I know it would be a really bad idea to drive with it in 4hi in the snow with that up there.
How much are we talking for the square driveshaft? Is this something I could do myself? I have been shying away from anything considered "trail only", but I guess I will go and search a few places for info on a square shaft up front. Thanks.
Chris Sutton
Golden, Colorado
1985 Toyota 4Runner - Longfields, 5.29's, EZ Locker F/R, Marlin X-Over, Rancho 99012's, 35" BFG AT KO, 414K miles.
1996 FZJ80 stock with 191K miles.
1980 FJ40 stock with 85K original miles.
Re: Front Driveshaft Recommendation [Re: ad54runner] #424459 03/31/04 06:54 PM
DirtyHarry Offline
Toyota Moderator
With full lockers front and rear I would venture to say that you will never want to run 60 mph in 4WD. Sorry, I know that this is not what you want to hear. Brian McCamish went through something similar and now runs an ARB, perhaps he can comment more.
As for the square shaft, check out this thread.
Re: Front Driveshaft Recommendation [Re: DirtyHarry] #424460 04/01/04 05:55 AM
TNToy Offline
Go square. It might be booty fab, but it's hella stout, 18"-travel-for-$30 booty fab.
Ever try to dent a reciever hitch?
Re: Front Driveshaft Recommendation [Re: TNToy] #424461 04/01/04 06:19 AM
4Crawler Offline
Depending on the collapsed length and slip yoke travel, you may be able to make a good shaft now that will have enough stretch later for the dual cases.
I had spare shafts built for my 4Runner that will fit on either end of the truck, I built them for the collapsed length needed up front (about 33" as I recall), yet they extend enough to fit in back. I just had the shop fill what wasn't CV or u-joint with splines, I think it pulls out to about 48".
And its not the end of the world to have a shaft lengthened, it usually runs under $100. I had my front shaft lengthened 2 times in stock form, then had it converted to a long slip yoke when it was lengthened the last time when I moved my axle forward the last time.
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.012s) Memory: 0.6153 MB (Peak: 0.6971 MB) Data Comp: Off Server Time: 2026-11-18 11:44:48 UTC
