Re: 2000 Trooper: Tranny Down!! [Re: taro] #426916 04/02/04 09:19 AM
taro Offline
something else i remembered about the alternator. i'm glad a guy with a good reputation tested it because the guys at autozone tested my alternator and reported it tested fine. apparently, it started faltering as the load was increased. good luck, taro
Re: 2000 Trooper: Tranny Down!! [Re: glock] #426917 04/02/04 05:44 PM
bob large Offline
i'm looking at 125k. abit more than you. <img src="/forums/images/graemlins/smile.gif" alt="" />
Steve C
Re: 2000 Trooper: Tranny Down!! [Re: glock] #426918 04/03/04 05:39 AM
hunterdan Offline
Sounds like a problem in the torque converter. My dads
F-150 had a similar problem. It wouldnt go when you released the brake and only then it would go when you got on the gas and then it would spin the tires. Not exactly sure what happened, but that seems to be similar.
92 Rodeo, 3.1 TB crank, custom bumpstop spacers, DOR shackles, Flipped ball joints, D44 Rear, 4.56s and new magnaflow cat and dynomax ultraflow muffler Since been replaced by a 2 door Explorer on 31's shackles, cranked torsion bars and full exhaust
Re: 2000 Trooper: Tranny Down!! [Re: hunterdan] #426919 04/04/04 04:50 AM
chasespeed Offline
at 1250, it sounds like the front pump. The tq/con will not put any noticable load on the motor if the pump is bad. NOW, if the pump was going, it would've taken out a few things with it. The pump is what builds the pressure in the tranny, to "make things happen". If it was going bad, then the increase in engine speed would cause a rapid increase in pressure, the it would slam in to gear. Anyway, hope this shed a little light on the subject, of course, I could be totally of on this as well....
my 2 cents....
Chase
Chase
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6089 MB (Peak: 0.6647 MB) Data Comp: Off Server Time: 2026-06-07 09:46:36 UTC
