Re: Coating on Frame, WTF? [Re: CORunner93] #427651 04/02/04 05:57 AM
Kaptain Offline
Yup, I'm in the same situation.. I dont know if it was the PO or dealer aftermarket.. The truck was obviously not prepped very well since there is undercoating on the driveshafts, lines, hoses and just about everything else under there.. I have removed most of it (atleast where i have had to do work on the truck). The simplest way i've found to remove it is to tap it with a hammer to break it apart and then scrape it off.
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
Re: Coating on Frame, WTF? [Re: Kaptain] #427652 04/03/04 04:33 AM
CORunner93 Offline
Another method for removing the stuff is a power washer. I spent $5 at a self service car wash...took all the loose stuff right off.
Don't go knocking that undercoating either...the rubbery black stuff they put on underneath does work if applied properly. The key is nice thin coats just like paint.
When some hack artist does it, they spray the stuff everywhere and put it on way too thick....very bad.
When done right the rubbery finish of the stuff protects against small rocks and gravel that get kicked up underneath by absorbing the small impact and preventing the rock from scraping the paint off.
When it's done wrong (and it usually is) little crevases and bubble get formed that actually trap moisture in the worst places.....and in no time at all the body and frame start to rot.
The milky white junk they spray in the door jams is garbage though.
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5948 MB (Peak: 0.6429 MB) Data Comp: Off Server Time: 2026-06-21 12:55:14 UTC
