Page 3 of 4 1 2 3 4
Re: Strongest idler arm you can get [Re: DaphneD] #428097 04/04/04 04:45 PM
Nitteberg Offline OP
It was the radiator, that was in the way, could move it, but you don't need a functional box either, just the main shaft.
http://nitteberg.com
-83 Pajero SWB Soft Top 2,3TD
35x14,5x15 PitBull Rocker
Bodylift, LSD, PTO-winch, Intercooler, 2.85 gear's
Gen2 upper a-arms, flipped and raised ball
Re: Strongest idler arm you can get [Re: DaphneD] #428098 04/04/04 06:11 PM
Kevin C Offline
I don't know if this makes any difference, but the pitman arm stud is on a swivel joint like the tie rods and ball joints where the idler stud just turns on a straight axis. Perhaps that would absorb the shock?
I have no doubt Nittenbergs setup works very well.. and congragulate him on this "in the box thinking" smile
Doug does point out a little know design feature.. that is one steering component typicly controls the linkage in rotation (along the axis of the steering gear).
The reason this can be important is the if all your pivot points are not lined up (the balls on the inner tie rods. idler arm steering box) as you rotate the relay rod (the big link through the center) you will get a toe change.
By putting one pivot in the front that keeps the linkage oriented properly this is reduced.
I have not taken the Montero arm apart but other Mitsubshi designs are typicly done with a rubber bushing in the joint (along with the pivot).
Again... not huge problem, but it is something you should at least be aware of. It gets more import if you tweak the relay rod or if as you rotate the rod you get a toe change.
My old plymouth Arrow (Mits design) had this problem, all the joints checked out fine (seemingly) but it still wandered. Putting a new arm in fixed it since.
People know that this fixed the problem, but were not realy sure why.
Kevin
Re: Strongest idler - lets make a group purchace and [Re: Lester] #428099 04/04/04 10:19 PM
lee_raider Offline
If anyone wants a steering box, let me know soon. I have one I'm ready to toss in the garbage. If you want it, you'll need to pay shipping.
Two MRI's and a CAT scan....it's confirmed. I'm just not right in the head.
Re: Strongest idler - lets make a group purchace and [Re: lee_raider] #428100 04/05/04 03:39 AM
Lloyd Swartz Offline
Hmm, hold that puppy for me if nothing else. I am going to run this idea by my mechanic/ fabricator monday.......
Re: Strongest idler - lets make a group purchace and [Re: Lloyd Swartz] #428101 04/28/04 03:46 PM
Lloyd, what did you turn up on this? On my SWB project the idler is frozen. A new costs $60 and I have three extra steering boxes at this point...
Re: Strongest idler - lets make a group purchace and [Re: MontyMcV] #428102 04/28/04 09:54 PM
Mine is tested, and works fine. Se the pic's
http://home.no.net/niva/Bilder/slide5/index.htm
Re: Strongest idler - lets make a group purchace and [Re: Nitteberg] #428103 04/28/04 10:29 PM
So, just remount it 180* and bolt it on? I will open up a pump tonight, never been inside one. I'm guessing that what you cut off still leaves behind what you need to the shaft down to the Pitman to continue to function...
Re: Strongest idler - lets make a group purchace and [Re: MontyMcV] #428104 04/29/04 05:13 PM
That's correct
Re: Strongest idler - lets make a group purchace and [Re: Nitteberg] #428105 04/29/04 05:27 PM
Thanks. I thought I had an extra in storage. Turns out is for the Quest. I will have to wait until I pull apart the Raider frame this weekend. I'll post back...
Re: Strongest idler - lets make a group purchace and [Re: lee_raider] #428106 04/29/04 10:23 PM
BobShaw Offline
My steering box is leaking so I could use one for an 87 Raider. Glad to pay for it if it does not leak.
Bob Shaw
superchief87@adelphia.net
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6465 MB (Peak: 0.7522 MB) Data Comp: Off Server Time: 2026-06-17 04:13:03 UTC
