buds 94 toy truck with 22re and noisy lifters #429244 04/04/04 06:34 PM
merikgvr4&sr Offline OP
Good morning, bud just got his truck and wanted to give her the once over. I tried to adjust the lifters but it still noisy and he doesn't like it. I am thinking of getting some lifters from the jy, is that a common problem with 22r engines? Thanks in advance for any help.
89 Malljero 4dr V6
94 Monstero SR (sold)
91 GVR4 turbo powa too many mods
83 300TD turbo diesel powa
Re: buds 94 toy truck with 22re and noisy lifters [Re: merikgvr4&sr] #429245 04/04/04 10:22 PM
The 22r/re series engines do not have lifters. The rocker, so common on pushrod engines is often called a "cam follower", as it is a compact overhead cam design. This series of engine has its roots in the relatively crude 1970's, so a completely quiet 22re would a rare animal indeed. The most common noise occurs when soft alloy rocker adjuster tips deform on the contact surface that touches the valvestem. In fact, the greatest problem occurs on THE INTAKE SIDE OF CYLINDERS #2, AND #3! This is because plastic rocker shaft spacers are used ONLY on these locations, and they will wear into the side of the rockers, causing mis-alignment.
Toyota offers metal spacer rings that will retrofit with these 2 worn rockers (you only need two, and they can be replaced on a completely assembled engine!!), at a cost of $5 each. Adjuster tips are $4 each from the dealer (DO NOT TRUST ANY BUT THE FACTORY PIECE OF THIS ALLOY CRITICAL PART). You will probably not need all eight. A smooth hourglass shaped wearmark on the contact face of the tips is completely normal. A boogered and hammered surface is not.
Important link (BOOKMARK ME!):
http://www.wheelingadventures.com/Tech/Fixs.htm
These spacers work great! DO NOT be alarmed if you see all the rockers offset a little to side of the valvestems. This is normal, and is probably there to put a small amount of spin on the valvestems to greatly increase life of the valveseats.
Re: buds 94 toy truck with 22re and noisy lifters #429246 04/04/04 11:57 PM
Thanks redknuckles for the clarificaton. Will let my bud know about the spacers.
89 Malljero 4dr V6
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5915 MB (Peak: 0.6463 MB) Data Comp: Off Server Time: 2026-06-20 06:57:23 UTC
