Re: 1987 Montero 5 speed Tranny problems HELP! [Re: Kevin C] #429655 04/08/04 12:50 PM
I just got thru helping a friend rebuild a 5spd with 285k on it (worn out synchros) that had almost no bearing wear. The tranny had been rebuilt at about 13k miles, and the owner had used nothing but dexron (NOTE - not gear lube) in it since. Bearings were all suprisingly tight. Thrust plate was ok (and was the upgrade part) but was slightly worn. This is the second time I've seen dexron used or recommended by a tranny tech for the KM145, and I'm beginning to be a believer. Lower friction losses from lower viscosity lube, and may be a better gear lubricant...
Re: 1987 Montero 5 speed Tranny problems HELP! [Re: Kevin C] #429656 04/08/04 02:44 PM
hi kev,
i'm in virginia, the raider is in california. if it were closer i would look into it further. thanks for the tips.
Re: 1987 Montero 5 speed Tranny problems HELP! [Re: fasteddy] #429657 04/08/04 06:02 PM
NathanC Offline
I remember you mentioning this before Eddy. You have me starting to wonder too. The company that rebuilt my transmission recommended using 10W30. I've been running Mobil1 in it since then. This tranny has lasted much longer that the previous rebuilt which I used gear lube in.
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: 1987 Montero 5 speed Tranny defective #429658 04/08/04 06:13 PM
TobyB Offline
Mitsu made a change to the box in mid- 86 for the '87 model year. They beefed up the countershaft bearings to a tapered roller, but didn't do anything to RETAIN the bearing better- which was, in a word, stupid, since tapered rollers produce significant side load when unevenly loaded. Like in a transmission.
There's an uprated part to use when the transmission's rebuilt (it has more metal and is machined rather than stamped) that retains the main and countershaft bearing. Sadly, I can't find part #'s now...
Also, be really careful about your choice of rebuilders- this thing went through a dozen minor changes and upgrades in 86-87, and the manuals aren't really clear about it. Heck, I don't think MITSUBISHI really remembers what was done!
Mine had been built (before I bought it) by a local shop, and they removed a spacer that the manual says was removed in July (my car has an Oct build date) and the transmission promptly ate the 3-4 shift fork. I rebuilt it, asked 2 or 3 people, didn't replace the spacer- and the tranny ate another fork! Ya, the 3rd time, it got the spacer!
My 2c would be to hit the yards- get an '88 4- cyl transmission, pop the bottom cover and make sure the countershaft doesn't have much end- to- end play, and drop it in.
If you run with it grinding, it eats the end off the 5th gear hub, as the end of the synchronizer hub runs into its driving gear. So I'd fix it as soon as you can. And use 4th a lot in the meantime- it bypasses the countergear, so you don't do more damage.
hth,
Toby
have done the transmission thing too many times...
'89 V6 4dr- '4- Doris'
Re: 1987 Montero 5 speed Tranny defective [Re: TobyB] #429659 04/08/04 07:47 PM
Kevin C Offline
That thrust plate is mentioned in a TSB, my 88 transmission had a problem with it as well. It was way too soft and when it pounded out it not only let the main shaft move back an forth it allowed the counter shaft to loosen.
That change was made in the Starion... Probably back in 84 or so. The needle bearing counter shafts failed very easily. Once you fix the plate problem you have a pretty strong transmission.
Definatly worth getting the better part from the dealer. Also shimming the counter shaft to zero clearance seems to help.
I machined up a spacer for the main shaft that also engauges the snap ring for even more support.
Kevin
Re: 1987 Montero 5 speed Tranny defective [Re: Kevin C] #429660 04/13/04 05:06 AM
philCA Offline
I have also had the rear thrust plate failure where the rear main shaft bearing started to ream out the thrust plate. The first sign of the failure was a fore and aft movement of the shift lever on acceleration/deaccelation. The next result was slipping out of gear. If someone else has worked on the transmission, it is wise to check the three 1-2 and 3-4 shift rods detent ball/spring/plug preload. It is not mentioned in some editions of the FSM. The correct depth from the top of the plug to the case is .22-.24 in. The small end of the spring goes next to the ball and sealer is applied over each plug. This does not apply to the neutral detent.
1987 Raider 2.6L 5 spd w/ LSD off road package 130K miles
1987 Conquest 2.6L 5 spd w/ intercooler 56K miles
2000 4Runner locking RA 34k miles
Re: 1987 Montero 5 speed Tranny defective [Re: philCA] #429661 04/15/04 07:38 PM
tbonesdam Offline
Nice Tranny6 Knowledge Breakdown!!! If I were To just drop an Auto Tranny in my rig would the wiring have to be yanked from an auto also????????
SELF MADE CHOP TOP W/HARD TOP.87 5 speed 2.6 less Balance shafts.Raider 88 Rust-O-loomed Body.Herculined Interior.Rust-proofed Frame.(Eastwood Stuff)Prothane Bushings.33x12.50.3in. Body Lift.2in. SHackle Lift + Torsion Crank.
89 Dodge Raider V6 Auto
90 Mitsu Montero LS so Clean!
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.012s) Memory: 0.6259 MB (Peak: 0.7215 MB) Data Comp: Off Server Time: 2026-11-04 19:56:57 UTC
