Re: ring gear bolts??? #430254 04/07/04 09:21 PM
RAZZMATAZ Offline OP
Just got off the phone with them.. No dice on the 11mm,
Thanks for trying,
RAZZ
87 4Runner 22R-TE
4 Pro Comp IFS
63 Chevy springs
5.71 gears
Detroit in rear, Lockright in front
35 MT/R
Rancho 9000
Jacobs ProStreet ign module and Ultra coil
1992 3VZ-E swapped in
Re: ring gear bolts??? [Re: RAZZMATAZ] #430255 04/07/04 09:37 PM
ZUK Offline
10 bucks....ok, I will try to take that up....let me try a few places.....about 25+ mm x 11mm x 1mm.............
mostly stock
Re: ring gear bolts??? [Re: RAZZMATAZ] #430256 04/09/04 12:41 AM
ZUK Offline
man, you were right Razz....I tried 2 of the biggest operations here in the Phoenix area....no go. I don't think you want to re-tap the holes....well, you might want to but the tap won't cut the hardened material....and may snap off in the hole anyways. I could be wrong though.
mostly stock
Re: ring gear bolts??? [Re: ZUK] #430257 04/09/04 03:22 AM
Yea i thought about the tap snapping off too.. But I'm going to try a few hols on my old 4.10s first..
I also went over to my parants house and dug up all my old gears and stuff, I found the original bolts that came out of this locker when I bought it. the bolts are a little longer but only by about 1-2 threads..
Thanks for you help,
RAZZ
87 4Runner 22R-TE
4 Pro Comp IFS
63 Chevy springs
5.71 gears
35 MT/R
Rancho 9000
Re: ring gear bolts??? [Re: RAZZMATAZ] #430258 04/09/04 03:28 AM
ZUK Offline
Can't take the locker to a machine shop and have them counterbore the 10 holes?
mostly stock
Re: ring gear bolts??? [Re: ZUK] #430259 04/09/04 04:04 AM
thought about that too but the back side of the of the locker is only about 5mm thick which is about what I need to cut out.. thought about trying to machine the ring gear side of the locker which is very thick, but that would move the ring gear over.. I don't thick I could make up the differance with the adjusting nuts on the side..
I have my 3rd member installed in my 4runner right now so thats why I can't take any pictures.. but there's one on ebay that's similar to mine.. the one on ebay looks like it's a little bit older and it broke so I bet that's why they made that part thicker.. this unit also looks like it was a cast piece, the one I have looks like it's a machined piece..
RAZZ
87 4Runner 22R-TE
4 Pro Comp IFS
63 Chevy springs
5.71 gears
35 MT/R
Rancho 9000
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6168 MB (Peak: 0.6863 MB) Data Comp: Off Server Time: 2026-06-21 12:08:56 UTC
