Re: Clicking In The front End ?
#430609
04/06/04 11:25 PM
And For Note The Clicking Im Geeting Is Only Or I Can Only Here It When Im In Frist Gear Or Under 15mph Going In A Stright Line Not Turning ? Thanks Nick
#430610
04/06/04 11:49 PM
I was getting a clicking sound coming from my passenger side front, actually it was kinda loud, but i only heard it when i was turning to the left or everynow and then when i went over some bumps. When i got home i took the wheel off and discovered that the top pin in the brake callaper that holds the pads in had sliped out and was rubbing up against the wheel. Might be completey different then what your hearing but it's worth looking at.
[Re: 92Pickup]
#430611
04/07/04 12:55 AM
will do i just did my brakes so this could be ill check cuz i didnt notice it till after i did the brake job ill be off at 5 ill post if that is it
#430612
04/07/04 01:03 AM
will do i just did my brakes so this could be ill check cuz i didnt notice it till after i did the brake job ill be off at 5 ill post if that is it It is the pads bouncing off the rotors until they warm up!~~ Does not happen as much with OEM pads. You might need to buy some new anti-rattle spring thingies from the dealer. Nothing really to worry about!!!!! <img src="/forums/images/graemlins/smile.gif" alt="" />
"Serenity through Sobriety"
[Re: OOP'S]
#430613
04/07/04 04:21 AM
will do i just did my brakes so this could be ill check cuz i didnt notice it till after i did the brake job ill be off at 5 ill post if that is it It is the pads bouncing off the rotors until they warm up!~~ Does not happen as much with OEM pads. You might need to buy some new anti-rattle spring thingies from the dealer. Nothing really to worry about!!!!! <img src="/forums/images/graemlins/smile.gif" alt="" /> Yes cuz now i notice it when i tap on the brake pedal lightly it not a click its a taping (lol) Thanks OOPS And All Other Peps That chimned in Nick
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6040 MB (Peak: 0.6682 MB) Data Comp: Off Server Time: 2026-06-21 12:07:57 UTCValid HTML 5 and Valid CSS
