Clicking In The front End ?
#430599
04/06/04 05:34 PM
I know that one of my balljoints are bad but i got this clicking in the front end and the hubs are not locked it only happens once in a while is it the CVs?
Also when i turn the steering wheel i get what sound like two ald rusty metal parts rubing together Balljoints? Or somthing with my steering ? Thanks Nick
Re: Clicking In The front End ?
#430600
04/06/04 06:23 PM
The Cv's wont be turning at all if your hubs are unlocked(Unless your t-case is in 4wd). Sounds like your steering stops need greased.. 4x4wire has a writeup on this..
93' Toy xCabbobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
[Re: Kaptain]
#430601
04/06/04 07:13 PM
steering stops need some marine grease <heavy> on them
#430602
04/06/04 07:21 PM
I did that front end mantinance.Still clicking when im going stright ? wheel bearings?
#430603
04/06/04 07:25 PM
And For This (Also when i turn the steering wheel i get what sound like two ald rusty metal parts rubing together Balljoints? Or somthing with my steering ?) this only when im in the cab just warming it up and i slightly turn the wheel left to right its not as bad as the wheel stops rubing not even close to that bad Thanks Nick
#430604
04/06/04 07:28 PM
It's possible.. The next thing i would do is take the hub and rotor off and have a look at the wheel bearings.. They might just need repacked with grease..
#430605
04/06/04 07:34 PM
You say it makes the noise while your warming it up? Well forget the wheel bearing idea then.. Take a look at your idler arm, they are prone to get alot of slop in them.. There's also Idler Arm info on 4x4wire...
[Re: Kaptain]
#430606
04/06/04 08:08 PM
Ok im going to do the idler arm thing but what do you think about the clicking ?
#430607
04/06/04 09:07 PM
I have a question along the same line. My 1990 4x4 sounds similar i think. When I have the steering wheel fully rotated either way it its a little stronger then a click but similar. Maybe even alittle banging but again only when its full rotated either direction. Same problem?
1990 Toyota 4x4 22 RE. My life!!!! My project continues! Always. I'm convinced it is an addiction. Still Running great after a year.
2000 Jeep Cherokee Sport. STOCK version.
[Re: Summermedic]
#430608
04/06/04 11:22 PM
Now That Is The Steering Stops Put Some Grease On The Bolts In Front And Back Of The Wheel And If Its Not The Stops Check The Steering Box
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6249 MB (Peak: 0.7294 MB) Data Comp: Off Server Time: 2026-06-24 12:37:49 UTCValid HTML 5 and Valid CSS
