Clicking In The front End ? #430599 04/06/04 05:34 PM
I know that one of my balljoints are bad but i got this clicking in the front end and the hubs are not locked it only happens once in a while is it the CVs?
Also when i turn the steering wheel i get what sound like two ald rusty metal parts rubing together Balljoints? Or somthing with my steering ?
Thanks
Nick
Re: Clicking In The front End ? #430600 04/06/04 06:23 PM
Kaptain Offline
The Cv's wont be turning at all if your hubs are unlocked(Unless your t-case is in 4wd). Sounds like your steering stops need greased.. 4x4wire has a writeup on this..
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
Re: Clicking In The front End ? [Re: Kaptain] #430601 04/06/04 07:13 PM
steering stops need some marine grease <heavy> on them
Re: Clicking In The front End ? #430602 04/06/04 07:21 PM
I did that front end mantinance.Still clicking when im going stright ? wheel bearings?
Re: Clicking In The front End ? #430603 04/06/04 07:25 PM
And For This (Also when i turn the steering wheel i get what sound like two ald rusty metal parts rubing together Balljoints? Or somthing with my steering ?)
this only when im in the cab just warming it up and i slightly turn the wheel left to right its not as bad as the wheel stops rubing not even close to that bad
Thanks
Nick
Re: Clicking In The front End ? #430604 04/06/04 07:28 PM
Kaptain Offline
It's possible.. The next thing i would do is take the hub and rotor off and have a look at the wheel bearings.. They might just need repacked with grease..
93' Toy xCab
Re: Clicking In The front End ? #430605 04/06/04 07:34 PM
Kaptain Offline
You say it makes the noise while your warming it up? Well forget the wheel bearing idea then.. Take a look at your idler arm, they are prone to get alot of slop in them.. There's also Idler Arm info on 4x4wire...
93' Toy xCab
Re: Clicking In The front End ? [Re: Kaptain] #430606 04/06/04 08:08 PM
Ok im going to do the idler arm thing but what do you think about the clicking ?
Re: Clicking In The front End ? #430607 04/06/04 09:07 PM
Summermedic Offline
I have a question along the same line. My 1990 4x4 sounds similar i think. When I have the steering wheel fully rotated either way it its a little stronger then a click but similar. Maybe even alittle banging but again only when its full rotated either direction. Same problem?
1990 Toyota 4x4 22 RE. My life!!!! My project continues! Always. I'm convinced it is an addiction. Still Running great after a year.
2000 Jeep Cherokee Sport. STOCK version.
Re: Clicking In The front End ? [Re: Summermedic] #430608 04/06/04 11:22 PM
Now That Is The Steering Stops Put Some Grease On The Bolts
In Front And Back Of The Wheel And If Its Not The Stops Check The Steering Box
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6259 MB (Peak: 0.7304 MB) Data Comp: Off Server Time: 2026-06-21 06:31:18 UTC
