Re: Add A Leaf & shocks [Re: averkam] #434464 04/15/04 07:44 PM
mt_goat Offline
I did the re-arched and add-a-leaf thing too. It lasted for a few years. Then I went with the new $500 custom Alcan springs and they were too stiff and too high. I removed 2 leaves from each of the Alcan leaf packs and added the air shocks and I'm perfect. If I load up the back with stuff I'm good at about 80-90 psi in the shocks. If I'm empty in the bed 30 to 40 psi is great. It gives you great flexability for load leveling. <img src="/forums/images/graemlins/smile.gif" alt="" /> I'm very happy with them.
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: Add A Leaf & shocks [Re: mt_goat] #434465 04/15/04 08:59 PM
A
averkam Offline
I stand corrected. I did not think about that.
You are using them to complement your newer springs. I would not be very comfortable using them to effectively replace worn-out springs.
When I had my springs re-arched the only reason the truck did not sit even lower is because they stopped on the over-load leaf. If I would have used air-shocks it would have been the only thing supporting my truck.
2000 Ext Cab SR5 4WD 2.7L 5-speed.
Re: Add A Leaf & shocks [Re: averkam] #434466 04/15/04 09:14 PM
mt_goat Offline
You have a good point there. With my air shocks at zero pressure I sit about one inch low, with an empty bed. It just depends I guess how much you are sagging. With my old stock springs and the add-a-leaf, I was sitting about 2 inches low, with an empty bed.
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.011s) Memory: 0.5995 MB (Peak: 0.6527 MB) Data Comp: Off Server Time: 2026-11-16 01:23:24 UTC
