Re: IFS and tire size #434502 04/14/04 02:16 AM
i run 35" with a 3" body lift and t-bars cranked 1.5". i also have a v6 with 4.88 which runs fine in the flat lands of Va. Where in Va do you live?
danville 25 min. from martinsville thanks guys after my over excitement i've come back to my senses. 35s and all that but any way i feel like the 4:88s 33s w/3in" bl will do what i 'm looking for i can see this becoming something of a sickness is ther a helpline for toyota 4x4 owners who can't stop building up ther rigs <img src="/forums/images/graemlins/smile.gif" alt="" />
mark
Re: IFS and tire size #434503 04/14/04 03:11 AM
Sid's Toy Offline
I re-geared to 4.88 and still run 31's. I love it except for highway. My rpms are not to bad when cruizing 70, 3100 but I'm actually only doing 63 or 64 mph corrected for regearing. If I actually want to do 70, my speedo says closer to 78 and rmps are now closer to 3600. It just takes me a little longer to get where I going when I'm cruizing the runner.
Sid
92 4Runner SR5 3.0 standard tranny
4.88 gears, rear elocked, OME coils, SAW Tbars, allpro rock sliders and rear bumper, custom made front, downey v6 headers ...
Re: IFS and tire size #434504 04/14/04 04:07 AM
grandeyota Offline
I ran 35's for years with my 90 IFS and 3" body lift. Chopped some fender up front. It wore out the idler arm and I've had to do CV boots. I'd guess that stuff goes after 14 years anyhow though. Switched to 4.88's about 2 months ago from the 4.10s and its very nice on the highway and in the mud too. Around town on 33's it's a big differance for the better. I use 36's off in the mud and it's a nice combo. Theres not much to flex on in FL so it just about never hits fender and works fine for mud/water from what I've done. Just make sure you get the right offset for your wheels or 35's will put a nice polish on your swaybar when you turn. As far as strength from the IFS parts, I've had no real problems. Go for it.
Fur clog in the sausage grinder
Re: IFS and tire size [Re: averkam] #434505 04/14/04 06:43 AM
elripster Offline
Fuel mileage is more a function of frontal area and speed than it is engine RPM.
Taller truck with wider tires = more frontal area = more wind drag = worse mileage.
Speed is even worse because it is squared. For example crusing at 80 requires 30% more power than crusing at 70.
Combine both of these and you will take a truck that out of the box did high teens and you should not be surprised by a truck that will do mid teens.
One more thing. Maximizing mileage will minimize performance. I am a big fan of low gears and would put money on that fact that it has less effect on mileage than people give it credit for.
Well put! I found lower gears help around town mpg at the expense of freeway but overall, it remained unchanged or changed very little. It simply takes energy to fight the fixed drag forces as you have described and gears are not in those equations.
Frank
1994 4runner, 3.0, auto, 4.88's, 31's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos.
www.sdori.com
Re: IFS and tire size [Re: elripster] #434506 04/14/04 08:35 AM
i forgot to mention i'm missing 3 inches of my fenders..
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6063 MB (Peak: 0.6715 MB) Data Comp: Off Server Time: 2026-11-01 13:20:46 UTC
