Spam is BAIT, not food. <img src="/forums/images/graemlins/barf.gif" alt="" /> <img src="/forums/images/graemlins/barf.gif" alt="" />
Tis a happy day; found the
Man Meals thread intact. Good chow!
From Eric D: Camping Fajitas - prepare stuff before you go!
1 red bell pepper
1 yellow bell pepper
1 green bell pepper
1 large onion (white, sweet, or yellow.. don't matter)
3 to 6 ounces white meat chicken breast, already cooked - for convenience, a couple of brands like Tyson, etc sell packages of pre-cooked, chopped white meat chicken that is usually in the sandwich meats section of grocery stores... or you can have the deli super-thick slice you some cooked, chopped and formed chicken - if you don't feel like cooking the chicken the old fashioned way or don't have time
one, 2-quart (or larger) ziploc bag and one 8-oz (or larger) ziploc bag
1 packet of fajita or taco seasoning
soft taco size flour tortillas
Serves 3 to 6 people depending on appetite.
Preparation: Before you leave, slice or dice the peppers and onion and stick them in the 2 quart ziploc bag (really it ends up just barely over 1 quart)
*Slice the chicken breast into "fajita size" strips and stick that into the other ziploc bag, and pour the seasoning packet in with the chicken.
To cook: dump both bags into big pan or wok, hold over fire, and stir frequently enough to keep stuff from burning.
I have never found it necessary to add water but if your veggies were very dry, you might want to have a little bit of water nearby to shake into the pan halfway through cooking if it starts to look dry. Be sparing with the water, though - it's easy to overdo it.
If the food isn't sizzling, you're not holding it close enough to the fire or the fire's not big enough. Stir/cook at least until all of the seasoning is mixed evenly with all of the vegetables - cook to desired tender/crispiness.
Portion the veggies and meat into the tortillas and enjoy. You can generally get more than a dozen good sized fajitas out of this.
Doug H's Fluffy Eggs with Cheese Sauce aka, the HeartStopper.
Fry up 5 slices of thick cut bacon. (The key is low low heat, and cast iron)
Then you make Cheese sauce (you make white sauce then mix in your favorite cheese). Basically you melt 4-5 tablespoons of butter in a sauce pan. Then mix in 3 tablespoons of flour, with some spices and 3 teaspoons of salt. This part is done over low low heat. Once it is blended well add 1 cup of whole milk, or light creme. Turn the heat up to medium. When the sauce thickens, add your cheese, and tada, the perfect sauce.
Separate 4 eggs, and whip the egg whites and the yokes separately. To get the whites nice and foamy you use 2 tbs of water... and a pinch of salt. Use a electric mixer, dont waste your time trying to do it yourself. Then you blend in the yokes and mix it together.
Remove the bacon, but keep the grease in the skillet. Heat grease until it sizzles when water is placed in it. Then pour the egg mixture into the skillet.
Cook as you would normal scrambled eggs. Remove and pour cheese sauce over eggs. Put bacon on the side.
Enjoy. These will be some of the fluffiest eggs you ever had. Call your doctor later in the day.
