Re: Intake manifold gasket replacement by a gimp [Re: rattler98] #435188 04/16/04 11:02 AM
icu_runnin Offline
yeah no highjacking but A LOT of my ?'s have been answered in this thread. thanks guys. i too was have that same leak. i thought it was coming from there but couldnt see how from under. i replaced the dist. o ring twice thinking the first was bad. i will wait to replace my gasket until i get my 4.3 tb. From the looks of it is the holley upgrade larger than the stock 4.3? and are the roller rockers a drop in install?
Re: Intake manifold gasket replacement by a gimp [Re: icu_runnin] #435189 04/16/04 02:15 PM
chasespeed Offline
First off, if you are talking about the GM 4.3, remember, it is esentially a small-block with the front 2 cylinders loped off. The pistons, con-rod, bearings, rings, are all the same as the era 350..identical part numbers is bought individually. The vavletrain is the same as well. And, most, if not all 4.3s came with a roller cam. The rollers, for soemone who is familiar with working vavletrains, yes, they are a "drop in". The hardest part for most people is settign the lash without collapsing the lifters, BUT, if you get a Haynes, or other manual that covers a vehicle with that motor, you will be covered. And holley upgrade? which part are you talking about. I know I may have missed something. And yes, we always use RTV between the manifold and block in the front rear...
My 2 cents
Chase
Chase
Re: Intake manifold gasket replacement by a gimp [Re: chasespeed] #435190 04/16/04 02:18 PM
chasespeed Offline
Dude, NOW I know I am still sleeping..sorry. Okay disregard my last post. But, yes like I stated earlier, the rollers ahould be relatively easy..just be carefull setting lash....
Chase
Chase
Re: Intake manifold gasket replacement by a gimp #435191 04/16/04 06:50 PM
JohninLV Offline
Fel-Pro gasket set P/N MS 91022 comes with two gaskets, distributer o-ring and a tube of black RTV.
Good book: How to rebuild GM V-6 60 degree Engine by Tom Currao, Motorbooks International.
Ebay has Trooper service manuals on CD. I havent tried one yet but will. My Helms is getting very dog eared.
Gm 10-30 Light Duty Truck 1987 Service Manual covers the 2.8L TBI engine better then the Trooper manual. Don't know if the GM manual is on CD, I lucked into my set at a used book sale for $.50 each.
John in Lv, good luck
3 90 Trooper V-6's, 5 speed, 4.3L TBI, 31" BFG AT's, Fender Flairs, Bored intake, 1.6 roller rockers, MSD Coil, Jacobs Omni ignition. Heavy duty torsion bars, Rancho 9000 Shocks CAN'T SPELL, TO OLD TO LEARN, GOD BLESS YOU IF YOU CAN.
Re: Intake manifold gasket replacement by a gimp [Re: JohninLV] #435192 04/17/04 05:15 PM
Have I told you how much this forum rocks? Just in case-THIS FORUM ROCKS! Thanks for all the replies and even more questions that make me want to do more. Already started hunting at the boneyard looking for a good condition TB and Intake Manifold. <img src="/forums/images/graemlins/pfft.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6090 MB (Peak: 0.6740 MB) Data Comp: Off Server Time: 2026-06-24 22:08:27 UTC
