main seals #435942 04/16/04 02:24 AM
rdtoytrk Offline OP
Hi all, I'm a newbie to the board. I'm looking for some info. regarding the front and rear main seals. I have to tackle a new clutch and timing chain in the near future and from what I've read on the bord, would like to replace the seals. Are there any links (w/pictures) or posts related to what I'll need for the job? I'm new at this but I'm willing to give it a shot. I bought a Toy manual but am not sure where to look for these seals. Any info. would be of great help. Thanks.........
Re: main seals [Re: rdtoytrk] #435943 04/16/04 02:31 AM
The front main seal is easy to do while doing the T-chain, and if you have the trans out and the oil pan off the rear should be a breeze also. one thing you may want to have on hand is a set of speedy sleaves(fix grooves) just in case the surface that the seal rides on is messed up...................Karl
Re: main seals [Re: rdtoytrk] #435944 04/16/04 02:54 AM
G
GeriatricToy Offline
Welcome to the board <img src="/forums/images/graemlins/cheers.gif" alt="" /> We'll take baby steps here K? A little something your going to want to know is...how to get that ***** crank pulley nut off <img src="/forums/images/graemlins/bird.gif" alt="" />. Yer gonna want to take a 19mm socket and place it on the end of a breaker bar. Parking brake set and trans in park or neutral, put the socket on the pulley bolt, place the other end of the breaker bar over the drivers side frame. Pull your coil wire and just touch your ignition. This will loosen the crank pulley nut. Any other means of trying to get it off will just tick you off....and the bolt will still be there <img src="/forums/images/graemlins/lol.gif" alt="" /> You'll prolly need a puller to get the pulley off. Install is reverse sept when you put in the new seal, put a little oil on it and when installing the pulley, go slow and straight. If you need help with the T chain, just hollar. <img src="/forums/images/graemlins/cheers.gif" alt="" />
2000 Tacoma SR5 - Bone stock 'cept a little bling.
2000 Tacoma SR5 - Bone stock.
Re: main seals [Re: rdtoytrk] #435945 04/16/04 02:59 AM
DRTDEVL Offline
Got a few minutes (hours)?
Check out 4-Crawler's website... Any question you might ever come up with can be answered here. If you think you learned a lot on this site, wait until you see his page! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: main seals [Re: rdtoytrk] #435946 04/16/04 03:27 AM
kewlynx Offline
Welcome! Timing chain article is over in the maintenance section; good document.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6056 MB (Peak: 0.6671 MB) Data Comp: Off Server Time: 2026-06-23 18:19:14 UTC
