33" tires on IFS along with rubbing (pics)
#436367
04/16/04 10:16 PM
Here is A <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> pic of my truck on it's new feet. Also, there is a pic of the clearance issues with 33" tires on IFS. This truck has 3" suspension, 3" body lift and the rims are 15x8 with 3 5/8" offset. They rub more on the driver side(for some reason it sticks out farther) http://community.webshots.com/album/134832833dNaHeTSteve
'97 Rodeo 3.2L V6 DOR 3" lift, 3"BL, DOR Boulder Bars, Tera-Low's, 33x10.5,Surco Safari Rack, Cobra CB, Rancho 9000's....andnNow with Half-Doors for the summer
Re: 33" tires on IFS along with rubbing (pics)
[Re: Jonesy]
#436368
04/16/04 10:29 PM
That looks really cool man! Good job! Hopefuly the rubbing is not too bad, just rememebr that you need minimal rubbing at full crank and on full compression. I bent my fender a little beacuse i did not take compression into account. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Good job man! It looks tough!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
1998 Isuzu Rodeo -- slightly modified.
[Re: Jonesy]
#436369
04/16/04 10:44 PM
it looks cool, but you'll lose that piece very quickly <img src="/forums/images/graemlins/shiner.gif" alt="" /> ![[Linked Image]](http://www.mindspring.com/~mjblp/a1.jpg)
[Re: Jonesy]
#436370
04/16/04 10:45 PM
Looks <img src="/forums/images/graemlins/kewl.gif" alt="" /> nice color also. Doug
[Re: Bansil]
#436371
04/16/04 10:52 PM
Looks great bro...
Hopefully mine will be done soon...
Chase
Chase
[Re: chasespeed]
#436372
04/16/04 11:32 PM
sexy <img src="/forums/images/graemlins/rodent.gif" alt="" />
1994 Isuzu Rodeo LS - Straight Axle 1992 Isuzu Trooper - Stock
#436373
04/17/04 12:23 AM
it looks cool, but you'll lose that piece very quickly <img src="/forums/images/graemlins/shiner.gif" alt="" /> You'll need this, too: ![[Linked Image]](http://mfinley.com/gif/sledgehammer.jpg)
Jeff Mason
Whatever makes you upset in someone else...also exists in you
[Re: Jeff Mason]
#436374
04/20/04 07:43 PM
Jonsey...Oh, that's who you are! I drive past your Rodeo parked at work there on main street (or is it West Temple?)all the time. I need to stop in and take a closer look at it.
EZ
#436375
04/21/04 04:24 AM
I believe we had this discussion before Steve. Those folks that profess that they can get 33's on a 1st gen Rodeo with only a 3 inch suspension lift and no body lift like yours and mine without rubbing are smoking crack. You can trim that little portion in the back without gutting it, but once you do this at full lock your rear of the tire will hit hard on the frame and the front of the opposite tire will hit on the body mount metal. Go to lowes and get 70mm bolts the size of your steering stops and replace them. It changes your turning radius but it will not rub anymore. I also had to grind down the tips of those body mounts because they were cutting my MT/r's. If you need any tools give me a shout. BTW, you've been missing some awesome wheeling this year!
1995 Honda Passport; Some people wait a life time for their ship to sail in, while others simple grab the oars and begin paddling Yours truely http://www.zutah.com
[Re: Paddler]
#436376
04/21/04 03:59 PM
Thanks for the compliments. Yep, that is mine, sitting on West Temple everyday. Jeff, as far as missing goes, I missed the meeting because I was doing the trimming(hoping to finish and make the meeting along with the wheeling <img src="/forums/images/graemlins/rolleyes.gif" alt="" />) The way I trimmed it may have been a little different then others.
I took off the flare and but a wedge out of the fender. Larger at the bottom and followed the arc of the well. The wedged stopped about 1/3 of the way through the arc. Then I did this to retain all of the original mounting holes for the liner and the flare. I then hammered the front part of the arc(with all the mounting holes) back against where the rest of the fender is. I then tried to tack weld it(I say try because doing sheetmetal with an acytelone welder isn't easy.) I kept blowing holes in the metal. I finally got it tacked in place after burning the paint off in 2 seperate areas <img src="/forums/images/graemlins/shocked.gif" alt="" /> Then I bolted back on the flare with a litle persuasion to line up the bottom since the arc no longer matches the flare. Overall it worked, now I need to pull it all apart and finish tack welding it and then sand/prime/and paint the spot I burned away.
Overall it worked out pretty well. I wish I had taken pictures but I was in such a rush trying to make the meeting I didn't get to. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Oh yeah, and the backspacing of my wheels is a little less then yours Jeff so I shouldn't rub the frame. Of course I only have 10.5" wide tires right now also.
