Page 3 of 3 1 2 3
Re: synthetic blend or full synthetic? - update!!!! [Re: anthonyn] #437281 04/20/04 06:58 PM
Canucklehead Offline
BTW, I compared the thread height of the fumoto plug with the stock plug and it matches perfectly. This means that the fumoto plug does not extend any further into the pan possibly reducing oil drainage. I worried about this a bit when I ordered the plug, but it turns out to be a perfect replacement.
Checking the Fumoto threads against the stock drain plug threads isn't going to tell you whether or not the Fumoto plug will prevent complete draining of the oil pan. You need to check it against the depth of the oil pan threads. I would be surprised if the oil pan was as thick as the drain plug threads are deep (~3/4" to 1" if I remember correctly) and would almost guarantee that the stock plug extends up above the bottom of the oil pan.
Steve
'97 Rodeo 5spd. 3.2L SOHC V6 4WD
Re: synthetic blend or full synthetic? - update!!!! [Re: Canucklehead] #437282 04/20/04 07:39 PM
A
anthonyn Offline
True. Your logic makes sense. I had a subaru oil pan apart before and the plug area is reinforced and built up to be flush with the end of the plug. I assume that this is the general case, since there seems to be like a dozen or so standard oil plug sizes that are used by most car/truck mfgs.
From Fumoto's FAQ:
Q. Does my Engine Oil Drain Valve protrude into the interior of the oil pan and prevent full drainage of my engine oil?
A. No. The threaded oil drain plug hole is always reinforced to accept the threaded bolt of the drain plug. In most cases, the Engine Oil Drain Valve will not extend past this threaded portion of the drain hole and will allow the oil to be properly drained. Your Engine Oil Drain Valve will let you drain your engine oil while it is hot without burning your hands and it is much more effective than trying to pump the oil out from above.
If assuming the above is correct, then the fact that the fumoto valves threaded section was the same size as the original plug, then there should be no drainage problem. But, next oil change I will measure to be sure <img src="/forums/images/graemlins/wink.gif" alt="" />.
95.5 Rodeo, Auto, Dynomax muffler, modified air intake, Manik Nerfs, clear corners, JVC MP3 player ...babied and nurtured since birth
Re: synthetic blend or full synthetic? - update!!!! [Re: anthonyn] #437283 04/20/04 08:40 PM
If that's the case I might pick one up.
I just changed my oil on Sunday and if this thread had been posted earlier I could have checked. Oh well, only about 2950 miles to go until the next change. PM me with what you find out. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Steve
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6043 MB (Peak: 0.6589 MB) Data Comp: Off Server Time: 2026-11-03 11:37:27 UTC
