Well I have been running this bumper for well over a year and it has taken some serious abuse! Everytime I go wheeling I end up landing on it pretty hard and I've been hung up on it a few times. It hasn't deflected enough to contact the tailgate and those booger welds of mine have held up just fine.
To further affirm its strength, I managed to get rearended once and back into someone once with the bumper. Both times the other guy received significant damage, but this bumper survived without even cosmetic damage.
Not long ago I built a fold-down hi-lift carrier to go on the bumper and that has worked out great for me. Details on that can be found
here. Here is a picture with the carrier installed:
![[Linked Image]](http://www.jordanbrosracing.com/cjnn/toypics/hvsvra/images/100_1323.jpg)
Originally I planned to continue with the box tubing around the sides of the truck using mitre cuts. But after seeing a few done that way, I decided it looked too much like a bumper car. So, a year later, I finally got around to cutting it into something I like:o. Here are some pictures.
I started by cuttnig the tube with an angle grinder and cutoff wheel
Next a heat & beat was in order
A couple c-clamps helped align things and keep the seam together
I used a stick welder for this. I haven't used one but once in a class three years ago, so I was happy to get decent welds. I have gotten MUCH better at MIG welding and have used a MM175 with success on rock sliders and other doodads
After the welding was done, I cut the ends with a taper. I'm tired of hanging up on rocks!
Next came cleanup with the grinder
And finally a spray bomb![[Linked Image]](http://www.jordanbrosracing.com/cjnn/toypics/bumperhack6.jpg)
I decided to leave the ends open so I can still use the HiLift at the corners of the truck.
In case anyone is wondering, the mounting outriggers were cut down to make room for the shackles on my longer Chevy springs. I added some gussetting up top (the most I could fit between my current bolt pattern and without interfering with the tailgate) and I've abused it this way for many trips wtihout incident.
Cheers <img src="/forums/images/graemlins/cheers.gif" alt="" />
