Gen 1 coil spacers #438121 04/20/04 02:30 AM
Hambone Offline OP
I've been having problems with the search and can't find the info.
Someone had posted about making molded urethain(spelling?)spacers. I am getting ready to get my 3.0 running and believe this is the route I am going to take. Anyone know the thread covering this topic or if the person making the spacer is ready to take orders?
My other option is having a set of longer springs made. Someone had posted the data need for a spring maker to use to build a set. There is a spring maker local I might be able to work with, if I have the info.
TIA for any help.
89 Raider 2.6L
89 Raider 3.0
Both history!!
KIA for rainy cold weather KLR650 most of the time!
Re: Gen 1 coil spacers [Re: Hambone] #438122 04/20/04 02:44 AM
Hi Hambone,
Not sure how you searched but I found several threads.
To help with future searches, here are a couple of hints...
1) Ensure you select one or more forums on the left side of the search page. You can select multiple forums but depressing the [ctrl] key while you select multiple forums.
2) Use + before any manditory search terms. Use - before any search terms you want to exclude.
3) Select the correct amount of days, months, years to search back.
Here are a couple of links that came up when I searched for "+spring +coil"
Coil Spacer Link 1
Coil Spacer Link 2
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5888 MB (Peak: 0.6372 MB) Data Comp: Off Server Time: 2026-05-26 13:51:19 UTC
