Re: u bolt flip on trapped springs??? [Re: 4Crawler] #440059 04/28/04 02:24 PM
Dok Offline
Thanks for the measurements, I was just kinda guesstimating after taking some quick ones with a tape measure laying under my truck!
'87 4-Runner--DD/wheeler, 4.3 swap coming soon
'89 Supra--E85 powered 2jz NA-T Swap, 533rwhp 497ft-lbs
'89 Festiva, turboed BP swap powered by megasquirt
Re: u bolt flip on trapped springs??? [Re: 94krawler] #440060 04/28/04 03:54 PM
4Crawler Offline
can i take the trap off the spring when i do u bolt flip.i know the axle perch is wider but im thinkig it shouldnt affect anything taking it off.it doesnt really seem to serve much of a purpose being there that i can tell.
I think it was added as a noise reducer, encase the springs in a rubber-lined box then clamp the whole thing with the spring plates and u-bolts. If you remove it, you will have a fairly large gap between the springs and the u-bolts so there is a risk of some of the leaves shifting and twisting, especially if used off-road.
If you were to grind notches into the side of the perches to allow the u-bolts to fit tight to the springs, or just leave the box around the leaves, then it would be OK.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5969 MB (Peak: 0.6452 MB) Data Comp: Off Server Time: 2026-06-07 10:16:52 UTC
