Steering way sensitive #440525 04/24/04 04:55 PM
Junkie Offline OP
Just finished my 86'. I have a 4.5" Rubicon Express Lift, 3" Body lift, TJ Flares & 39 Swampers. I have replaced the steering components w/ Currie pieces, rebuilt P/S box(NAPA), new drop pitman arm, Borgeson shaft (Everything). The steering is tight, no play at all & just had it aligned & it tracks great. I have one steering stabalizer. O.K. for the problem. The steering is so sensitive that any movement I make, basically I'm changing lanes or darting over. My questions is what can I do to tighten the steering up or make it less responsive. If I move the wheel at all it just takes off in that direction. Just doesn't give me a good feeling when doing 65 - 70. Any and all input is always appreciated. Thanks in Advance.
Re: Steering way sensitive [Re: Junkie] #440526 04/25/04 11:40 PM
There's an adjustment on the top of your steering box. It takes and allen wrench with a locking nut around it. I've been messing with mine all week trying to find a happy point. Not sure if having it too much one way or another is a bad thing for your steering box or not....so experiment at your own risk!
Re: Steering way sensitive #440527 04/26/04 05:38 AM
too much tight will shred the innternals.....
Re: Steering way sensitive #440528 04/26/04 02:41 PM
I have never had to adjust that allen head nut on the top of my steering box. You should only have to adjust it every 150k miles or so. It's not a freeplay adjustment on the steering. If steering is loose or tight it's a 96% chance it's not in the box, it's other places.
I have no good tech other than that. They didn't sell you a fast ratio box, did they? Did everything grease alright after you installed it all? Is this a stock axle, or did you cut it down to fix the rig in this buildup? SOrry I'm of no real help <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: Steering way sensitive [Re: Junkie] #440529 04/26/04 05:45 PM
W
wranglert Offline
the re-built steering box being too tight is fairly unlikely but you never mentioned the size of the steering wheel? if you're running a small wheel with all that new stuff it could be overkill especially with tires that will have a tendency to follow imperfections in the road. just a guess again you didn't talk about the size of the wheel
90 wrangler 6 cyl. 97 honda passport 84 dodge longbed 4x4
Re: Steering way sensitive [Re: Junkie] #440530 04/26/04 07:19 PM
W
wranglert Offline
this makes four tries at getting this post to show up
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6023 MB (Peak: 0.6701 MB) Data Comp: Off Server Time: 2026-06-22 13:59:44 UTC
