Time to replace the u-joints? #440897 04/25/04 05:45 PM
A week or so ago the truck started to squeak whenever it is under load up to around 40 mph. Once they start to squeak is it too late to save them? I didn't realize that that are greasable. 42000 miles seems a little premature for a joint to go out. I'm guessing the p/o never took care of them.
Thanks
Re: Time to replace the u-joints? #440898 04/25/04 06:37 PM
E
EQuin Offline
42K miles does seem a little premature for the u-joints to be going out. Block/chock the tires and put it in neutral. Rotate the driveshaft and check for play in the u-joints (also check for the squeaking sound you mentioned). If they look good, then grease them up. If not, you can remove the driveshaft and try the various hammering, clamping and vise-grip methods to remove the bad u-joint. I find it easier to just take the driveshaft to a driveshaft shop, pay them $15, and let them have fun removing it. FWIW, Autozone has replacement "Brute Force" u-joints for about $13. Also, if one of your double cardan u-joints is bad, a driveshaft shop should be able to fix that, even though the manual says they're not rebuildable.
Hope this helps.
Ed Q.
03 TRD Tacoma Ext Cab 3.4L 4x4
93 Ford Bronco
86 Ford Bronco
47 CJ2A Willys
Re: Time to replace the u-joints? #440899 04/25/04 11:49 PM
I changed out the back one first and after that battle, I decided to let the front two go. I would have gladly paid someone 15 buck to do that. Brute force is what I used, non-greasable but they have a 12 month warranty. But she don't speak anymore so I'm happy.
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.5877 MB (Peak: 0.6423 MB) Data Comp: Off Server Time: 2026-06-20 07:28:51 UTC
