Alright, in the past month or so i've noticed some oil spots under my rig, looked under and saw a few things, didn't think much about it. Look under it yesterday with the lamp and whatever, it seems there's oil coming from around the #5 and 6 cylinders (both sides). Valve covers? I checked the dipstick, i haven't really lost any oil, (my engine doesn't burn a drop).. and i've had no overheating issues. It only started once it started getting warmer, i've been running a 5w30/lucas oil in a 4:1 mix during the winter, is that too thin and leaking thought the cover seals? I'm pretty sure it's not the head gasket, because oil cant seep through that right? I can get some pictures if need be, but most seems to be coming from around the 5 and 6 spark plugs (not from the plugs, around them), valve covers? Anyways, if it is the valve covers, think it would be a good idea to clean the injectors, add a high-output alternator, rebuild the PS pump and fix the AC at the same time? How about put in some new headgaskets with DOA studs and a new timing belt for preventative maintenance? Anyways, i was pretty pissed off yesterday when i saw the oil dripping out, but i'm gonna have a few people check it out. (valve covers are no big deal, i can figure them out). Vavle covers? BTW, my truck has 185k km on it if that matters... (and runs pretty strong for a stock 3.slow)...
89 4Runner 3" BL, M/T locks, 33"bfg mt, bilstein, Kayline, tubebumper, toyotafiberglass panels TBI: Elocker,3.4 w/ORS,b+b,S2Sstg2cams,arias pistons,P+P intake,TRDs/c,URDpullies+7th,downey headers,MAPECU2,WEGO WB, SupraMAF,walboro255,stg4clutch, EPaOo2 sim
