tacoma engines
#441296
04/26/04 04:49 PM
what are the differences between the 2.4L and the 2.7L? can 2WD tacomas be fitted with the 2.7L?
alfio
Re: tacoma engines
#441297
04/26/04 05:23 PM
alfio 8 HP and a bit more torque. I have the 2.7L in my Pre Runner.
Re: tacoma engines
#441298
04/26/04 06:27 PM
alfio the 2.4 and 2.7 are basically the same engine, the 2.7 has the same bore but longer stroke, and the 2.7 has balance shafts, theres no reason why a 2.7 couldn't be put in a 2wd non prerunner
Re: tacoma engines
#441299
04/26/04 09:03 PM
alfio the 2.4 and 2.7 are basically the same engine, the 2.7 has the same bore but longer stroke, and the 2.7 has balance shafts, theres no reason why a 2.7 couldn't be put in a 2wd non prerunner are the heads the same? intake/exhaust manifold, wiring harness, smog crap all pretty similar? thanks alfio
Re: tacoma engines
#441300
04/29/04 05:16 PM
Re: tacoma engines
#441301
05/02/04 06:22 PM
The 2.7l has some kind of distributorless ignition system. I guess this means it doesn't use traditional spark plug wires? Anyone?
Re: tacoma engines
[Re: agroal]
#441302
05/02/04 07:34 PM
What it doesn't usse is the traditional distributor older engines use to control the advancing and retarding of the spark timing. Instead the 2.7 has an ignition coil for each cylinder and a computer controls when to fire the spark depending on conditions such as air density to prevent the engine from pre-detenating.
Re: tacoma engines
[Re: agroal]
#441303
05/02/04 08:45 PM
The 2.7l has some kind of distributorless ignition system. I guess this means it doesn't use traditional spark plug wires? Anyone? Yes, I'm not sure which year they switched over to the new ignition. Mine has a distributor and wies.
joel
*1996 T100 2wd,long bed w/5speed Borla Cat-back *2002 Z28 Convertible *2002 Lightning *2005 Trailblazer
Re: tacoma engines
[Re: jabush]
#441304
05/03/04 02:38 AM
My 96 has the 2.7 with a distributor and spark plug wires but the coil is built into the distributor. According to Consumer Guide, they switched the ignition and fuel injection systems in 97.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6088 MB (Peak: 0.6940 MB) Data Comp: Off Server Time: 2026-06-22 17:05:29 UTCValid HTML 5 and Valid CSS
