Page 1 of 6 1 2 3 4 5 6
Looking for LOCKERS??????????????? #442103 04/28/04 03:46 AM
mattnsteph Offline OP
Found them! A friend of mine here in Korea I met thru one of out sportage clubs has one of the biggest Sportage clubs here in S. Korea. He got me in contact with a person here in Kunsan, by the AF base I am going to set up a meeting with the guy here Hopefully this weekend or the next. I will do my best getting them to the states. The lockers are made by track finder. More info soon.
In midst of building.
Re: Looking for LOCKERS??????????????? [Re: mattnsteph] #442104 04/28/04 04:15 AM
DamKia Offline
Kia Moderator
<img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
......as long as they make it to the land of Oz as well!
Front/rear/both( <img src="/forums/images/graemlins/smile.gif" alt="" />)?
Re: Looking for LOCKERS??????????????? [Re: mattnsteph] #442105 04/28/04 04:22 AM
from my knowlege they are both front and rear. I will have more info on the product itself after the meeting with them. Hopefully this weekend! <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Looking for LOCKERS??????????????? [Re: mattnsteph] #442106 04/28/04 06:48 AM
Dave Scott Offline
extremely good news, too bad i just cut everything off!
Re: Looking for LOCKERS??????????????? [Re: Dave Scott] #442107 04/28/04 12:00 PM
DamKia Offline
Kia Moderator
Dave, you will have to get another one so you can do side-by-side testing <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Looking for LOCKERS??????????????? [Re: mattnsteph] #442108 04/28/04 12:03 PM
DamKia Offline
Kia Moderator
Other bits on the wish list:
5.3 or higher R/P's,
Lower ratio gears for transfer case. (~2.5:1)
Re: Looking for LOCKERS??????????????? [Re: mattnsteph] #442109 04/28/04 05:28 PM
keep the wish lists coming when we meet, I want to ask him everything i can possibly ask him for parts.
Re: Looking for LOCKERS??????????????? [Re: mattnsteph] #442110 04/28/04 05:57 PM
Dave Scott Offline
ball joint spacers
diff drop kits
second the lo t-case gears
Re: Looking for LOCKERS??????????????? [Re: Dave Scott] #442111 04/28/04 09:37 PM
shifter26 Offline
bigger and stronger steering knuckles ...
longer struts ...
quick disconnect sway bars ..
longer brake lines ..
stronger master cylinder/booster ..
differential and t-case guards ..
solution for the right rear shock being dented from the panhard rod mount ..(trimming it a bit is still not enough .. the rear end still drops lower and hits it ..)
Re: Looking for LOCKERS??????????????? [Re: mattnsteph] #442112 04/29/04 12:18 AM
See if has or knows about getting headers for the Sportage.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6448 MB (Peak: 0.7751 MB) Data Comp: Off Server Time: 2026-06-20 22:41:23 UTC
