Page 5 of 5 1 2 3 4 5
Re: Pulling Auto Tranny....Question....updated with pics [Re: MrWiretender] #442304 05/27/04 04:41 AM
BigBri Offline
Hey Mrwiretender,
A couple more parts.
-If you have to smog the truck you'll need a little smog part up on the intake manifold, called a Dashpot or something. And the bracket.
-On mine, the top 2 bolts from the bellhousing to motor, were the wrong length after the swap. You'll probably need shorter ones like those on the bottom.
-Ofcourse the shifters
I could reuse my driveshafts, crossmember, flexplate/flywheel bolts, torque converter/pressureplate bolts, most bellhousing bolts.
I'm EXTREMELY happy with the results. Highly recommended swap.
Anything else, ask.
Good luck, Brian.
Re: Pulling Auto Tranny....Question....updated with pics [Re: BigBri] #442305 05/27/04 05:01 PM
G
Genshie Offline
Thanks for the info on the Dashpot!! I had no idea about that and I am due for my smog pretty soon. Gotta go find one now so I can pass. This thread is definitely the most complete I have seen in regards to the auto to 5 speed tranny swap.
Thanks again!
Kurt G.
Dented 85 4Runner courtesy of Wrecking Ball.
Re: Pulling Auto Tranny....Question....updated with pics [Re: Genshie] #442306 05/27/04 08:17 PM
BigBri Offline
Glad to help! I actually found mine on a 80's Celica with the 22RE, for $6, at the junkyard. :-) It kind of a pain to get on and off though, because the screws are on the underside of the Throttle Body. And don't forget the little adjustment screw that threads into the throttle linkage!
See ya, B.
Re: Pulling Auto Tranny....Question....updated with pics [Re: BigBri] #442307 06/11/04 03:23 PM
Elbow_Greese Offline
Dredging this up for personal gain (I hope) <img src="/forums/images/graemlins/shiner.gif" alt="" />
Do either of you that have done this swap still have your speedo cables?
Or were you able to use your old ones?
I need to replace mine (it broke), so if you have one I can get off ya, that'd be great!
Thanks!
Todd
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: Pulling Auto Tranny....Question....updated with pics [Re: Elbow_Greese] #442308 06/11/04 04:22 PM
RBA Offline
Still like to hear from people who did the 5spd swap on the V6 if there's any different from the 4 cyl. Since I would be doing this myself, are there any tools except for the tranny jack to use?
Chard
94 Runner V6 4X4 (gathering parts for 5spd swap and 3.4L engine swap)
Re: Pulling Auto Tranny....Question....updated with pics [Re: Elbow_Greese] #442309 06/12/04 12:31 PM
BigBri Offline
Sorry dude,
no extra cable here. I kept using the same old one. B.
Re: Pulling Auto Tranny....Question....updated with pics [Re: Elbow_Greese] #442310 06/12/04 12:32 PM
Runningman Offline OP
I was able to re-use the old one. Good luck!
Thanks!
Todd
85 Toyota 4runner with some stuff...
[color:"blue"]Trail Pics[/color]
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6274 MB (Peak: 0.7176 MB) Data Comp: Off Server Time: 2026-11-17 04:35:32 UTC
