low oil pressure #443830 05/02/04 05:12 AM
justtin00j Offline OP
I change the oil in my 92 amigo then drive it for 1000-1500 miles with the oil pressure normal. After 1500 the oil presure drops to zero when i turn around corners. Is this normal or is something messed up on my truck.
Re: low oil pressure [Re: justtin00j] #443831 05/02/04 05:31 AM
randii Offline
Check the oil level -- that sounds exactly like what would happen if you had a low oil level.
Randii
Re: low oil pressure [Re: randii] #443832 05/02/04 05:33 AM
i think i have to order another dipstick because every time i change my oil and check it the dipstick says i have to add more. I'll order it on monday.
Re: low oil pressure [Re: justtin00j] #443833 05/02/04 07:43 PM
holger Offline
Which oil you have, a synthetic ? Then it is normal.
With many synthetics the oil level is lower than it should
be, becouse some modern oils are very sticky and they stick
to the engine walls and the oil does not drain down quickly.
I have the same problem with my Royal Purple oil -
it always shows half quart below normal after the oil
change. Next morning it will drain down and the level
will be OK.
Oleg
Re: low oil pressure [Re: holger] #443834 05/02/04 10:09 PM
i use 10w-30 non synthetic
Re: low oil pressure [Re: justtin00j] #443835 05/03/04 02:57 AM
CPOM Offline
Your dipstick can't be broken. Its a metal rod. Even if the dipstick is bent and the tube is bent as well, it should still work exactly the same.
I would find out where your oil is going after 1500 miles. It could be a sign of a more complicated problem (burning oil). It could be leaking past the valve guides into the combustion chamber, past the oil ring which could be sign of bad rings or low compression, or even more problems... A new dipstick won't solve any of these.
CHRIS
98 Amigo, 92 Pup
Re: low oil pressure [Re: CPOM] #443836 05/03/04 02:24 PM
i guess i need to do a compression test.
Re: low oil pressure [Re: justtin00j] #443837 05/03/04 07:02 PM
what would i need to do to find out where i am leaking oil. if it's leaking from the valves how would i tell.
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.011s) Memory: 0.6195 MB (Peak: 0.7021 MB) Data Comp: Off Server Time: 2026-11-18 03:17:55 UTC
