RockStomper IFS Travel Kit ??? #44400 12/05/02 03:51 PM
mxitup Offline OP
I was curious as to why the RockStomper IFS Travel kit comes with bump stop extensions when it is required to have a 4" lift to install the RockeStomper kit to begin with. Don't all 4" lift kits for the IFS already have bump stop extensions installed ?
I was wondering because I'd like to order up RockStompers kit but was puzzled by this one item.
Thanks in advance for any input on this question <img border="0" title="" alt="[Smile]" src="images/icons/smile.gif" />
<small>[ December 05, 2002, 09:53 AM: Message edited by: mxitup ]</small>
Re: RockStomper IFS Travel Kit ??? #44401 12/05/02 03:59 PM
elripster Offline
The Rockstomper bumpstop extensions are shorter than those with the lift kit. This creates a larger space between the bumpstop and a-arm allowing the a-arm to travel upwards farther.
If you go to the tech section, there's an article on cross linked air shocks. It has a drawing of the bumpstop extensions I made for my truck. Check it out, might save you a buck and the ones I made are much stronger than the Rockstomper set up. They, of course, require a little time and labor to fab up but depends really what you have more of I suppose, time, money, etc....
Also, the cross linked air shocks will allow you to use all that new travel. Otherwise the t-bars are very stiff and will limit flex.
Frank.
1994 4runner, 3.0, auto, 4.88's, 31's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos.
www.sdori.com
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.5870 MB (Peak: 0.6352 MB) Data Comp: Off Server Time: 2026-06-22 23:52:14 UTC
