Freeing frozen tie rod end #444082 05/02/04 10:05 PM
80CJ Offline OP
I've been under my CJ-5 for the better part of the morning trying to adjust the tie rod ( I need more toe in) and the passenger side tie rod end just will not budge. It seems that the driver's side is free. I've used PB Blaster and tapped on the tie rod with a ball peen hammer. I've been trying to turn the tie rod with a 14 inch pipe wrench. I'm affraid of putting too much torque on the tie rod thinking that I might pull the tie rod end apart. Any suggestions?
Re: Freeing frozen tie rod end [Re: 80CJ] #444083 05/03/04 12:10 AM
Mudlover27 Offline
get a really hot tourch and heat that nut up then give it a tap, I have been there before with my jeep, somthing so easy is always suck a pain, good luck
Mud
Re: Freeing frozen tie rod end [Re: Mudlover27] #444084 05/03/04 12:39 AM
superdawg Offline
Good plan with the heat, but also if you get it to move freely remove it and antisieze it.
Also if you break the end with the pipe wrench, it was shot anyway.
SD
Re: Freeing frozen tie rod end [Re: superdawg] #444085 05/03/04 02:16 AM
80CJ Offline OP
Thanks a lot guys. The heat really worked. Just a propane torch but it did the job.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.5965 MB (Peak: 0.6518 MB) Data Comp: Off Server Time: 2026-10-27 06:00:15 UTC
