Tire Size... #444844 05/03/04 11:45 PM
Stock rim but ordered Bridgestone Dueler A/T Revo's 31 x 10.5 x 15's sound like there gonna fit?
Will I get worse fuel economy whats the benefits of running a larger tire?
Re: Tire Size... #444845 05/03/04 11:56 PM
yeah they will fit with no problems .i had 31's on mine and then i went to 33 inch super swampers so they will fit ...by the way i have only heard good things about the revo ...im sure those are alot quieter then mine ! <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Tire Size... #444846 05/04/04 04:05 AM
I first put my Michelins on when I had my 95 SR. I didn't notice any change in fuel economy...
Re: Tire Size... [Re: MontyMcV] #444847 05/04/04 05:00 AM
Lloyd Swartz Offline
31x10.50 is your STOCK size, you did not increase tire size! You might try searching for some basic info <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Tire Size... [Re: Lloyd Swartz] #444848 05/04/04 05:06 AM
Big Blue Offline
In one of your MANY posts on tires you said that you HAD 31's so I don't understand your question???????? What am I missing??
Kary
1987 Mitsubishi Pajero "Modified"
The other original Mitsu brother
Northwest Trailmaster
Re: Tire Size... #444849 05/04/04 05:22 AM
Kary's right. You mentioned you already have that size on your rig in this thread. Here...
You know that if the tire size say's 31x10.5 it means it will be 31 in diameter by 10.5 in width right? Even with tire size differences/tolerances it won't vary more than a half inch.
What's the deal?
Re: Tire Size... [Re: off-roader] #444850 05/04/04 11:56 AM
Tire rack said that the original equipement that comes on there is 235/75-15, so I got 31 x 10.5 x 15's
Re: Tire Size... #444851 05/04/04 02:45 PM
All SRs came with 31s.
Re: Tire Size... #444852 05/04/04 02:53 PM
Wait. You mentioned the tire size you had was 31x10.5 previously and you're replacing with 31x10.5.
That means you're replacing with the same size tire.
Now there are some slight size differences between various brands or models due to how much rubber and how it cures but the difference isn't more than a 1/2" or so.
To get back to what you were asking about... if it would fit. I guess you can say that yes... it will fit. I'm not 100% sure but I believe you can get up to a 33" tire under there w/ a torsion bar lift. If not 33, definitely a 32.
Re: Tire Size... #444853 05/04/04 02:54 PM
Big Blue Offline
There's a tag on the rig that TELLS you what tires you have as original equipment. Try opening the drivers door and LOOKING for it.
Kary
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.010s) Memory: 0.6345 MB (Peak: 0.7528 MB) Data Comp: Off Server Time: 2026-11-03 12:33:28 UTC
