Re: Teaching my Trooper to swim [Re: strawmyers] #448289 05/12/04 11:15 PM
well I gutted the interior of my truck, washed all the carpet and foam in the washing mashine and reinstalled everything.
Apperantly the only casualty of the water damage was 2 rear light bulbs and a 760 watt kenwood amp that belongs to my brother.
I even found a live salamander between the rockers and the plastic door molding. Its still alive too.
Re: Teaching my Trooper to swim #448290 05/12/04 11:34 PM
90amigo Offline OP
I only have bugs in mine.They come in via the branches from trees in the Ocala Nat forest.I have webs inside my truck the next day. <img src="/forums/images/graemlins/oink.gif" alt="" />
90 Amigo,Front 10 bolt with powertrax locker,Rear Dana 44 with Detroit Locker at 5:38.1 R&Ps,Pro Comp MT's 33x12.5 on 15x8 black Rockcrawlers,with a 3" suspension lift.Pro Comp steering Stabilizer.Warn M8000 winch in a ARB bullbar.
Re: Teaching my Trooper to swim [Re: strawmyers] #448291 05/12/04 11:57 PM
W
Wayne Offline
I pulled everything out. I pulled the vinyl and replaced the stinky under-padding with white shag carpeting I got from the local carpet store dumpster. Then I put the vinyl back in. Worked great, better fit, cooler floor, quieter ride, easy to do.
[color:"white"]? 04 Rodeo DI ?[/color] 75k mi, body damage on the 1st weekend I got it.
Re: Teaching my Amigo to swim [Re: strawmyers] #448292 05/19/04 01:59 AM
randii Offline
.... I wonder just how many 1st gen Amigos have been buried up over the headlights <img src="/forums/images/graemlins/shiner.gif" alt="" />
This one wasn't over the headlights...
...but on other occasions, I have taken in water over the tailgate in the rear while floating the tail end downstream. I was cranking in winch cable at the time whil crossing fast-moving water with my hand on the key, ready to shut-down if necessary. Thank Isuzu for fairly tight door seals! <img src="/forums/images/graemlins/ignore.gif" alt="" />
Randii
Re: Teaching my Amigo to swim [Re: randii] #448293 05/19/04 05:17 AM
Frog/salamander pond water does not smell too good when its soaked into all the carpet.
and the next time you get it wet, about a week after all the seeds carried in from the mud last time start sprouting, requiring either a lawnmower or a dose of weed spray.
It was deeper in before I manged to get 'out' this far, and lost traction. Open the doors and let the water run out.
But not nearly as bad as the time before that;
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6075 MB (Peak: 0.6729 MB) Data Comp: Off Server Time: 2026-06-21 16:15:02 UTC
