Page 1 of 3 1 2 3
The dyno numbers are in... #448323 05/11/04 12:15 AM
mosk Offline OP
Just got back from Dynospot Racing, a local dyno shop, and I have some numbers to share for the turbo truck:
The max numbers are [...drum roll...] : [color:"red"] 222.4 hp, 243 ft. lbs. @ 15 psi.,[/color] as measured at the rear wheels. <img src="/forums/images/graemlins/smile.gif" alt="" />
I am pretty pleased, as these numbers were obtained on 91 octane pump gas! This thing is a blast to drive, and makes me want to find some speed rated light truck tires, if there is such a thing.
When I first started this project, I felt that it might be possible to deliver as much as 300 hp to the rear wheels on pump gas and turbo alone. Obviously, it wasn't possible to run enough boost and advance on pump gas to do that. For the record, I have no doubt that with racing fuel I could easily run enough boost and advance to make 300 wheel hp...but that wasn't what I was after. I want a truck that makes turn-key power. Now, that goal may change if I get bored with what I have, but I don't think I will.
The motor only has 1000 miles on it, so I may see another 5-10 hp once the rings fully seat. Also, I've seen all sorts of numbers tossed around for driveline losses on 4x4's, but even a middle of the road number like 25% puts me at 300 hp at the flywheel, which is impressive. I think any way you measure it, I have more than doubled the stock 136 flywheel hp, which is pretty damn good. This motor rocks! Kudos to Tim @ D.O.A. for building a solid, deep-breathing platform utilizing his own custom head porting and turbo cam grind. And while some of these parts came right off the shelf, many parts (such as the throttle body + linkage, intercooler setup, and the exhaust, to name a few) had to be made by hand. Building this motor has been a lot of work! I don't know if I'd do it again, but it's pretty fun to drive the end result <img src="/forums/images/graemlins/smile.gif" alt="" />
So what's next? Driving it and enjoying it! And if I ever get the urge for more, there's always water injection <img src="/forums/images/graemlins/evil.gif" alt="" />
-Jeff
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: The dyno numbers are in... [Re: mosk] #448324 05/11/04 12:34 AM
Congratulations fron NZ Jeff ... have been following your progress for a few years now and pleased to see a positive outcome.
Andrew
Re: The dyno numbers are in... [Re: mosk] #448325 05/11/04 12:44 AM
DirtyHarry Offline
Toyota Moderator
Nice numbers Jeff! That torque curve looks pretty flat for a turbo motor too, I am sure that it pulls really hard now. Time to surprise some kids in Hondas. <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: The dyno numbers are in... [Re: DirtyHarry] #448326 05/11/04 12:48 AM
BoostedInline6 Offline
Congrats Jeff! If I had your truck I would be out smoking ricers all day long. Where did you dyno and how did the A/F chart compare to your wideband? I need one ASAP...
2000 4Runner | 5-speed | E-locker | Tundra/OME 2" lift | Stubbs Sliders | Deckplate/TrueFlow |
Re: The dyno numbers are in... [Re: BoostedInline6] #448327 05/11/04 01:11 AM
BigBri Offline
Hehe, really suprise em lighting up all four wheels!
Re: The dyno numbers are in... [Re: BigBri] #448328 05/11/04 01:16 AM
mosk Offline OP
Thanks, guys.
Ken: Dynospot (in San Jose) wanted an extra $40 to display WBO2 info. Since I have one built-in, I opted to pass...but since I also forgot to do any sort of datalogging during the dyno runs, it was all moot. Dynospot has a raised dyno setup, and for insurance purposes they do all the driving on the dyno. By the time I remember that I wanted to datalog the runs, my pulls were over and the car was being lowered.
No big deal, though; I'm sure I'll be back on the dyno again at some point.
-Jeff
Jeff Moskovitz
Jeff's 22R-TE page
Re: The dyno numbers are in... [Re: mosk] #448329 05/11/04 01:57 AM
jcssurf Offline
DEAR GOD
what is the rest of your trucks setup? like gears and wheels and tires?
seems like 4.11s (or 4.56s if you're an auto which i guess you probably are) with like a 31x12.50 BFG could be a fast ass setup without being too revvy
come over and let me drive it!
90 pickup, 22RE, stiff-ass Ranchos, 2.25 catback, 4:1 header, conical intake, 15x7 ICW alloys, 32x11.50 Dunlop Mud Rovers, 4.56s w/v6 rear
-Farm truck until school is done...then plans
2000 Honda CRV EX 5 speed
-Driver
Re: The dyno numbers are in... [Re: jcssurf] #448330 05/11/04 02:10 AM
G
Greg_Canada Offline
DEAR GOD
I think he's got 4.10's and 31's....
nice to see that dyno... your's is the first website i looked through while searching for toyota's... glad to see it's done... now go take it to the strip and kick some hoonda!
89 4Runner
Re: The dyno numbers are in... [Re: Greg_Canada] #448331 05/11/04 04:14 AM
L
LaCalavera Offline
Well I have to say that I'm very jealous of your motor! <img src="/forums/images/graemlins/drunk.gif" alt="" /> I also like how you've outlined the progress on your website. I'm glad everything is coming together so well for you. Now you just gotta make some time to have lots of fun w/your truck. Keep up the great work! <img src="/forums/images/graemlins/kewl.gif" alt="" />
White '91 22RE 4x4 Single Cab
Re: The dyno numbers are in... [Re: LaCalavera] #448332 05/11/04 06:11 AM
Those numbers are better than most supercharged 3.4 V6 dyno results. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.013s) Memory: 0.6395 MB (Peak: 0.7654 MB) Data Comp: Off Server Time: 2026-11-19 05:23:57 UTC
