89 trooper 2.6L 4ZE1 into 89 p-up?
#449013
05/12/04 03:36 AM
will this trooper motor swap into a same year p-up 5 spd 2wd. is the oil pan different? will the p-up tranny work? same clutch? are the trooper and the p-up 2.6 the same? any input would be great
Re: 89 trooper 2.6L 4ZE1 into 89 p-up?
[Re: doby/reddevil]
#449014
05/13/04 03:09 AM
This doesn't exactly answer your question but I put a 90 somthing PUP engine in my 88 trooper (Got off eBay). You really need a doner engine to swap the wiring harness (swap intakes). The PUP and the Trooper of SOME vintages have slightly different distributors and wiring harnesses. Everything else fit no problem. I have a spare manual wiring harness and PUP distributor if you want.
Good Luck,
Kevin
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.010s) Memory: 0.5870 MB (Peak: 0.6351 MB) Data Comp: Off Server Time: 2026-11-17 20:44:10 UTCValid HTML 5 and Valid CSS
