Re: carb not right [Re: doc long] #449218 05/14/04 06:41 AM
freebird Offline OP
i will lookin to the thang uall said to do but not to piss any one off i forgot to say the carb is two weeks old rebiuld from napa and been adjusted by the jeep dealer (taht i will not go back to for any thang).but i will try what i can when replaced i put new air lins and all.
bill <img src="/forums/images/graemlins/notooth.gif" alt="" />
90 YJ 35 trexis mt 4sup 3 body junk 258 new weber carb flat fenders rock sliders winch
Re: carb not right [Re: freebird] #449219 05/14/04 12:52 PM
W
wranglert Offline
try spraying the carb base gasket with carb cleaner while the jeep is running spray all around the base if it revs you have a vacuum leak and it sounds like a vacuum leak to me or the carb is way out of adjustment good luck <img src="/forums/images/graemlins/patriot.gif" alt="" />
90 wrangler 6 cyl. 97 honda passport 84 dodge longbed 4x4
Re: carb not right [Re: wranglert] #449220 05/15/04 11:48 PM
freebird Offline OP
ok i found out what the whole problem was two of the wire that go to the carb where broken i thank thay work the choke. my jeep now runs like a top <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> .thank you all for the help.
thanks
Re: carb not right [Re: doc long] #449221 05/19/04 02:59 AM
Doc, you got a couple of friends with a '90 YJ.
Mainly, the problem with these Carter/Webers (let's not drag all that out again !!) is vacuum and cleanliness. I did a total replacement of the Pulse Air system, and it worked well for a time.
I'd go with Big Jim on the warm up issue, easily. Mainly because he's done a million of these. Still, the stalling isn't really related to warm-up. It's generally the vacuum and that stupid little gum up issue.
These days, I can take my Street Princess out on the turn of the key.
Before, no way.
Pay attention, newbie. Sunder and Jim will do you right.
Re: carb not right #449222 05/19/04 04:21 AM
fishtaker Offline
Hey NYY where you been? havent heard from you in a while.
03 TJ 5 Speed I-6 30X9.50 BFG KO's
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6117 MB (Peak: 0.6729 MB) Data Comp: Off Server Time: 2026-05-29 23:42:13 UTC
