7.5" questions (now with pic) #450324 05/15/04 04:46 AM
mmiller Offline OP
I recently ordered some new gears and install kit for my 7.5" front (still unopened). Erik B's differential site says that the T100 front is the same as standard 7.5", which seems to be what I have based on his descriptions. Some sites say the the T100 front is the same as the Tacoma (late model 7.5")and requires reverse cut ring and pinion. Other sites say it is a standard cut setup; the same as older trucks? I'm a little confused.
Here an example
This site says Tacoma and T100 are reverse cut.
This site says they are 7.5" standard cut like older Toys, and different than Tacoma.
Secondly, my front diff leaked out the passenger side (ADD). Will replacing the needle bearings with standard bearings fix this? Is there I seal in there too, or do I need to replace some CV part?
Maybe the pic will clarify my question.
Re: 7.5" questions (now with pic) [Re: mmiller] #450325 05/20/04 03:01 PM
ErikB Offline
Toyota Moderator
Its for sure standard cut, the same diff as the '86-95 pickups and 4runners. The front diff in my T100 now is from an 80's 4runner.
As for the leak, there is a seal that you can replace. If there is a lot of play in that flange though, simply replacing the seal may not fix the leak.
http://home.4x4wire.com/erik
Re: 7.5" questions (now with pic) [Re: ErikB] #450326 05/20/04 03:24 PM
mmiller Offline OP
I was sure it was standard until I looked as some websites that implied it was reverse like Taco's. Maybe they don't know.
West Coast
Precision Gear
Thanks.
1997 T100 4x4 SR5 5spd
Re: 7.5" questions (now with pic) [Re: mmiller] #450327 05/20/04 03:30 PM
surlynkid Offline
West Coast
Precision Gear
Thanks.
they don't know. it is just like erik said.
don't swap out any needle bearings. check your seals. there is a seal in there.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
PHP: 7.4.33 Page Time: 1.099s Queries: 15 (0.003s) Memory: 0.6015 MB (Peak: 0.6585 MB) Data Comp: Off Server Time: 2026-05-30 20:25:25 UTC
