Re: Took my new Revos on a interstate drive today, had some vibrations, why??? #450339 05/15/04 09:09 PM
hoot Offline
At 35psi, every tire I have ever had on mine bounced like basketballs at high speed.
What does the Manufactureres sticker on the door suggest, assuming you are running original size tires?
'04 Taco double cab
Re: Took my new Revos on a interstate drive today, had some vibrations, why??? #450340 05/15/04 09:36 PM
Dandeman Offline
Toyota Moderator
I have them at 35PSI, what the guy at the tire place said to keep them.
I have Bridgestone Dueler ATs 265 70 x 16s and they need 35psi up front and 33psi at the rear to get an even wear pattern across the thread.. This is with the vehicle weight of 4540lbs..(The mods do add up). I have zero vibration in mine at that pressure.
Get them balanced properly..
Re: Took my new Revos on a interstate drive today, had some vibrations, why??? [Re: Dandeman] #450341 05/18/04 06:50 PM
JSharp Offline
I have 265/70 X 16 Revos set at 34psi cold on stock wheels. They are a bit "bouncy" at that pressure but no vibrations up to 90mph...
2000 4Runner SR-5, 4X4, 5 Speed, Toyota locker.
Dunlop R/T's, cheap mudflaps, remote oil filter, Deckplate, K & N filter.
My 4Runner
Re: Took my new Revos on a interstate drive today, had some vibrations, why??? [Re: JSharp] #450342 05/21/04 06:06 AM
9
94krawler Offline
id get them rebalanced.could be a bead wasnt all the way seated,it does happen.also set your tires to what the door jamb says usually get a much better ride.i havent seen a revo messed up yet and i work for bfs corp.id try balance first and seet air pressure to what the door jamb says. <img src="/forums/images/graemlins/smile.gif" alt="" />
94 toy truggy rolling on tons
>>>>>>>>www.Rightcoast4x4.com<<<<<<<<
Rockcrawling for the eastcoast.
Re: Took my new Revos on a interstate drive today, had some vibrations, why??? #450343 05/23/04 01:51 AM
Balance and/or alignment.
I've never seen an out of alignment issue cause a vibration. Pull yes, vibration no.
Re: Took my new Revos on a interstate drive today, had some vibrations, why??? #450344 05/31/04 05:55 PM
Sorry to bounce in here, but how is the wear on your Revos? I was initially very interested in them, but it seems that people haven't been getting many miles. Just curious.
Cheers,
Mark
Re: Took my new Revos on a interstate drive today, had some vibrations, why??? #450345 05/31/04 06:40 PM
Sorry to bounce in here, but how is the wear on your Revos? I was initially very inerested in them, but it seems that people haven't been getting many miles. Just curious.
Cheers,
Mark
So far they are great, they ride great and my 4Runner isn't nearly as bouncy as it was with the BFG ATs. I'm going to Myrtle Beach next week, so that will be the longest trip I'll have put on the tires, and I'll let you know how they wear after that.
Re: Took my new Revos on a interstate drive today, had some vibrations, why??? #450346 06/02/04 05:21 AM
larsdennert Offline
It's common on Toyotas for aligment to cause vibration/wobble in the steering wheel. If the vibration is felt in your feet more then its a balance issue.
Re: Took my new Revos on a interstate drive today, had some vibrations, why??? #450347 06/02/04 06:19 AM
James Chow Offline
Aren't Toyota wheels hub centric or something like that? I seem to recall they require a special balancing machine that many tire shops don't have.
'86 4Runner: ARB winchbar, Kaymar, e-codes, OME lift, RR diff lock, FR truetrac, sound stream a/d/s audio, recaros.
'03 LX470: ARB sahara bar, Kaymar, HID's, ART cryo'd/slotted rotors, Stoptech SS hoses.
'01 Prelude SH
'00 CRV
Re: Took my new Revos on a interstate drive today, had some vibrations, why??? [Re: James Chow] #450348 06/16/04 01:45 AM
have them re turn the tires and re balance them. return i mean deflate and re turn the tire to better balance out. good tire shop and mechanic will know what you are talking about prolly a few others on here know what iam tlaking about too. revo's should run like glass.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6325 MB (Peak: 0.7386 MB) Data Comp: Off Server Time: 2026-06-07 05:00:15 UTC
