Took my new Revos on a interstate drive today, had some vibrations, why??? #450329 05/15/04 05:10 AM
I went to Columbia today and it was the first time going on the interstate since getting my new Revos. I first got it up to 70MPH and it started vibrating, then 80 then vibrated worse, then 90 and worse again. After bout 20 mins it quit vibrating real bad and just did it a little, at all speeds. Any idea why it vibrated real bad at first, then just kinda quit vibrating?? Anything I should check out?
Re: Took my new Revos on a interstate drive today, had some vibrations, why??? #450330 05/15/04 05:30 AM
Balance and/or alignment.
Re: Took my new Revos on a interstate drive today, had some vibrations, why??? #450331 05/15/04 05:52 AM
azrain Offline
Yep. Take it back Eric.
Mike
Re: Took my new Revos on a interstate drive today, had some vibrations, why??? [Re: azrain] #450332 05/15/04 06:03 AM
Should I take it to a place that has that Hunter machine thing and the Hawkaka adapter?? I was just reading about it on Gadgets site, should I also get it aligned?
Re: Took my new Revos on a interstate drive today, had some vibrations, why??? #450333 05/15/04 06:40 AM
azrain Offline
Is your truck still leaning 1 1/4"? Man, that's quite a lean, you could have something in really bad shape there. Didn't you also replace all the shocks recently? There are so many dynamics that could be there, but if everything is in good shape, have the tires re-balanced and get an alignment. I can't imagine that the Revo would take a lot of weight to run nicely.
Mike
Re: Took my new Revos on a interstate drive today, had some vibrations, why??? [Re: azrain] #450334 05/15/04 10:04 AM
yep, get em rebalanced (roadforce tested) and you should be good to go! that hunter machine is the best
Re: Took my new Revos on a interstate drive today, had some vibrations, why??? #450335 05/15/04 06:25 PM
hoot Offline
What pressure are you running? I have a set of 265-70-16 Revos on my Tacoma, and they bounce at speed if inflated much higher than recommended. Drop the pressure to 26 or 27 psi, per card on door jamb, and they ride perfect.
'04 Taco double cab
Re: Took my new Revos on a interstate drive today, had some vibrations, why??? [Re: hoot] #450336 05/15/04 07:45 PM
I have them at 35PSI, what the guy at the tire place said to keep them.
Re: Took my new Revos on a interstate drive today, had some vibrations, why??? #450337 05/15/04 08:04 PM
Maybe the batteries are dead in your valve stems <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Took my new Revos on a interstate drive today, had some vibrations, why??? #450338 05/15/04 08:44 PM
Yea that's it.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6211 MB (Peak: 0.7256 MB) Data Comp: Off Server Time: 2026-06-02 13:02:40 UTC
