Page 16 of 16 1 2 14 15 16
Re: The TURBO CONVERSION Bible ADD 87 Starion B38 connector [Re: 87monty] #451255 01/18/10 06:50 PM
Hot diggity!!!!!!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: The TURBO CONVERSION Bible ADD 87 Starion B38 connector [Re: MontyMcV] #451256 01/18/10 08:11 PM
fasteddy Offline OP
wheeEEEEEEEEEEE
Now upgrade the brakes. You will need them...
Re: The TURBO CONVERSION Bible ADD 87 Starion B38 connector [Re: 87monty] #451257 01/25/10 03:44 PM
dadrab Offline
Huge congrats. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Beware, however of "Buzzicus Returniem." That's when the buzz you got when it first fired comes back at random times while driving - usually under heavy acceleration. <img src="/forums/images/graemlins/smile.gif" alt="" />
with awesome audio.
Re: The TURBO CONVERSION Bible ADD 87 Starion B38 connector [Re: dadrab] #451258 01/26/10 07:59 PM
87monty Offline
Holly Crap this thing is fun!!! Its the best when im at a stop light and rip off the line. At the next light I see people looking from front to back saying "What is that" A mini Rover with a V8!!! NO its a Turbo Montero Baby!!
Thank you for all your support I could have not did this with out you all,
Cheers all around <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: The TURBO CONVERSION Bible ADD 87 Starion B38 connector [Re: 87monty] #451259 01/26/10 10:37 PM
fasteddy Offline OP
tojaso...
Re: The TURBO CONVERSION Bible ADD 87 Starion B38 connector [Re: fasteddy] #451260 06/14/10 01:02 PM
A
airbats801 Offline
Here is a nice link for wiring up the ecu. The starion gets all its power n what not off the b38 plug. This link shows the 2 different b38 plugs and their pinout. Picture n all.
scroll down to the lower portion ofthe page where it takls about the b38
http://projectzerog.com/wiring-how_to.shtml
8 Starion SHP, 87 mitsubishi van, , 81 galant g54bt, 78 lancer g54bt, 1965 Mitsubishi Debonair Deluxe
87 swb montero offroad pkg goin g54bt with sr locker 33x12.5 dual bouncy.
Re: The TURBO CONVERSION Bible ADD 87 Starion B38 connector [Re: airbats801] #451261 11/05/13 03:32 PM
BTW, Master fuel pumps are manufactured under the Airtex brand now, and the recommended pumps listed on page 1 of this post are no longer represented. It appears that the closest equivalent is the Airtex E8228, which fortunately has both 5/16" inlet and outlet for simplicity's sake. It's rated 38 GPH at pressure up to 100-125 psi and is a rollervane design.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6330 MB (Peak: 0.7075 MB) Data Comp: Off Server Time: 2026-06-20 20:14:27 UTC
