noisy alternator...time to save $$$? #451568 05/17/04 11:29 PM
indy Offline OP
My truck has developed a high pitched noise that sounds
like the noise you might hear on your stereo speakers
if you didn't have a RF filter. The noise seems to
follow the speed of the motor and as best I can tell
it's coming from the alternator. It's still putting out
13.8v to the battery at this point but I'm curious
what would be causing the sound and how long I should
expect it to last now? I should note that I recently
replaced the drive belts. Thanks for any clues.
Regards,
Indy
Re: noisy alternator...time to save $$$? [Re: indy] #451569 05/17/04 11:32 PM
Staceman Offline
Just for giggles, can you remove the alt. belt, start it up for a few, and see if the noise still persists? That will at least rule out alt/belt.
Re: noisy alternator...time to save $$$? [Re: Staceman] #451570 05/17/04 11:44 PM
indy Offline OP
Yeah,I was thinking I'd try that tonight just to
see what happens. BTW I've been reading my FSM
and you gotta' drain the what (!) and remove the
what (!) to get that sucker out of there?! Those
Toyota engineers don't make it too easy on us
do they?
Regards,
Indy
Re: noisy alternator...time to save $$$? [Re: indy] #451571 05/17/04 11:52 PM
Staceman Offline
Don't know. Got me. I don't have a FSM, but I can loosen an alternator, and pull the belt without doing all that other nonsense. <img src="/forums/images/graemlins/coolg.gif" alt="" />
Re: noisy alternator...time to save $$$? [Re: Staceman] #451572 05/18/04 12:03 AM
indy Offline OP
The belt is easy...but if the unit itself has to be
removed it entails draining the radiator and removing
the bottom hose. Not too tough, just time consuming.
Regards,
indy
Post deleted by little_joe [Re: indy] #451573 05/18/04 12:17 AM
Re: noisy alternator...time to save $$$? #451574 05/18/04 01:25 AM
indy Offline OP
Well, I tried removing the drive belt from the alt. &
PS one at a time to see if the noise changes...no
change. I haven't driven my truck in a couple weeks,
so maybe I've just forgotten what it's supposed to
sound like. Guess I'll put this one in the 'if it aint
broke quit messin' with it' file for now and just keep
an ear on it.
Regards,
Indy
Re: noisy alternator...time to save $$$? [Re: indy] #451575 05/18/04 04:34 AM
Elbow_Greese Offline
If you do have to remove the alt, you don't have to drain the coolant.
I unbolted my PS pump and kinda twisted/moved it out of the way, and I was able to take tha alt out from the top.
I don't have A/C, so I don't know if that would make any difference. Don't think so though.
Todd
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6173 MB (Peak: 0.6956 MB) Data Comp: Off Server Time: 2026-06-14 01:23:18 UTC
