Suspected bad timing belt tensioner #452758 05/20/04 04:03 AM
Dark_Angel Offline OP
OK, I think the timing belt tension may be bad. The truck got stuck in water. I had to do a couple thing. I replaced the timing belt, but the is the loud taping coming from the front of the motor. I haven'tpulled eveything off and confirmed that's where the noise is coming from though. Something I noticed when I replaced the timeing belt was the the tension piston was extremely stiff. I had to put it in a vise to compress and put a pin in it. It took some work even with the vise. Is this normal?
This is on a 3.5 2000 Trooper motor.
Thanks,
2000 Trooper 4x4, Auto, TOD pretty much stock at the moment.
2001 Camaro Z28, M6, fully loaded and too many mods to list! AKA Dark Angel
Re: Suspected bad timing belt tensioner [Re: Dark_Angel] #452759 05/20/04 02:03 PM
I don't know what they sound like when they go bad.
I replaced mine when I did my timing belt. I needed a vise to compress the new tensioner. I suppose that means it's normal. Good luck. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5825 MB (Peak: 0.6320 MB) Data Comp: Off Server Time: 2026-06-19 00:10:20 UTC
