[Re: Bigpoppax2] #452905 06/01/04 03:59 PM
Re: 2.6 4ze I-Tec, idle speed, hesitation [Re: Bigpoppax2] #452906 06/01/04 06:54 PM
F
Frisky Offline
Here is a shot in the dark, but it happened to mine. I was having a bad idle situation after my (hack) mechanic did some work to my truck. I fought and fought with it, but one day, I got out the brake cleaner and starter spraying around the valve cover to see if there was a vaccuum leak
I would spray at the top of the valve cover, and the engine would rev up. I figured that I had some weird leak on the valve cover. I messed with it and messed with it until I felt the air rushing into the porcupine pipe!!!! The mechanic had apparently stepped on it breaking a 1" hole in the darn thing. I replaced it and the truck has gotten much better about the hesitation, and my check engine light has stopped flashing at me now. I would check for a lean condition from too much air or not enough fuel. I am wanting to say I was getting a code 12 from mine as well.
Just a thought from my experience
1992 Isuzu Rodeo 2WD (some assembly required). "If it doesn't fit....Force it!! If it breaks, it needed to be replaced anyway."
Re: 2.6 4ze I-Tec, idle speed, hesitation [Re: Frisky] #452907 06/01/04 08:04 PM
Not sure what happened to my last post but how do you reset the TBS? I did a search but didn't find what I needed.
Thanks!
Bill
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5942 MB (Peak: 0.6497 MB) Data Comp: Off Server Time: 2026-06-17 01:43:04 UTC
