Page 2 of 4 1 2 3 4
Re: revisiting the radiator issue [Re: BigJim] #454571 05/25/04 05:37 PM
jeepfun4u2 Offline OP
i am going to put some coolant into the system, run it for 30 minutes or so(parked), and see what happens. if i lose water parked when the radiator doesn't go past a temp of 240?, i will assume that i am losing it from the rear of the motor, where it will probably evaporate before hitting the ground due to heat. i'll clean the area around the cap really well first too. yes, i do have a new thermostat in it, and i dropped it into a pan of water on the stove first to make sure it opened, (bought a GATES thermostat, more reliable than some of the products to be found down here), and a new cap as well(GATES) several weeks ago. if the problem is a freeze plug, can this be replaced without pulling the motor? (i.e. pulling the tranny) thanks for the help, all good advice.....Rob
American in Mexico with my 76 CJ7,4.6 Liter I6
Weber 32/36,Header,FlowMaster,DUI Ignition
3"Lift,33's,TH400 Tranny/Dana 20
Re: revisiting the radiator issue [Re: jeepfun4u2] #454572 05/25/04 05:50 PM
yes freeze pliugs can be gotten easily without removeing the engine
Re: revisiting the radiator issue [Re: jeepfun4u2] #454573 05/25/04 06:53 PM
even the ones on the back of the motor?
Re: revisiting the radiator issue [Re: jeepfun4u2] #454574 05/25/04 07:16 PM
you'll have to pull the tranny, but not the motor, and you will prolly have to pull the flywheel, but all you need for that is an impact rench
Re: revisiting the radiator issue #454575 05/25/04 09:20 PM
thanks sunder, the thought of pulling the motor again under the circumstances as last time cause to turn in my sleep. the tranny i can handle much easier. rob
Re: revisiting the radiator issue [Re: jeepfun4u2] #454576 05/26/04 12:05 PM
valleycat Offline
how hot is it down there? i know in the summer here, if you leave a beer unattended for a short time, it's 100 degrees at 0 psi(open) and there won't be as much in it as before from evaporation.
Re: revisiting the radiator issue [Re: valleycat] #454577 05/27/04 12:46 AM
Well, I'm in the mountains at an altitude of about 9000 ft. (sucks for carbs!) so it only gets up to about 80-85 mid-day. I have the feeling that this is the problem though, and am going to pursue options to get my radiator temp down. it seems that all the water is boiling or evaporating out of my overflow tank. first, I'll buy a shroud. thanks for input, Rob
Re: revisiting the radiator issue [Re: jeepfun4u2] #454578 05/28/04 08:50 PM
okay, got it figured out. now i need a solution. radiator is just too hot. the overflow bottle overflows when running and then when cool sucks the water back into radiator causing a low level in the bottle. i have to get the radiator cooler. i am going to start with a shroud, any comments above that are welcome, by the by, i have an aftermarket fan with six blades, but who knows if it's doing a good job! actually the problem seems to be that the temp climbs highest when cruising at 60mph on the highway, not at idle or in the city. thanks again in advance. rob
Re: revisiting the radiator issue [Re: jeepfun4u2] #454579 05/28/04 11:05 PM
JeePete Offline
That makes it sound like a leaking head gasket or cracked head to me. Good luck. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: revisiting the radiator issue [Re: JeePete] #454580 05/29/04 03:54 PM
thanks for the advice. anybody else think the same? (head gasket/head)....rob
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.012s) Memory: 0.6376 MB (Peak: 0.7396 MB) Data Comp: Off Server Time: 2026-11-18 22:35:58 UTC
