Page 2 of 4 1 2 3 4
Re: A/C recharging? #455177 05/26/04 02:45 PM
So search with my name. You will find tons and tons of R134 Retrofit information....
I am certified for R12 but I wouldn't spend the money for it. I have done hundreds of retros without any problems. I can get R134 to cool just as good, if not better then R12 in an R12 system!!! Just needs done properly. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: A/C recharging? #455178 05/26/04 02:45 PM
You guys are talking me out of this. My 89 slowly lost all coldness, so am pretty sure it's a leak, but this all sounds like too much trouble and expense for a convertible. My 86 didn't even have AC and I never really cared, might just let this go.
Maybe I can gain some HP by disconnecting the ac? Is that belt connected to anything else important?
Re: A/C recharging? [Re: mainer] #455179 05/26/04 04:44 PM
foxtrapper Offline
i looked in walmart the other day and the kit was like $35, i didnt say anything about replacing seals or changing anything else....
what else do you need to change? i will be doing mine as soon as i get the cab back on my 85... is there an easy way i can check for leaks before i go to charge it? thanks
The step that is missing is using a vacuum pump to pull down the system completely emptying it of R-12, or air if that's what is in there. On these trucks, there is no problem with the hoses or seals when converting to R-134.
Post deleted by little_joe #455180 05/26/04 06:02 PM
Re: A/C recharging? #455181 05/26/04 06:31 PM
Red_Chili Offline
Toyota Section Staffer
HECK no! Convert it to on-board air! Front Range Off Road has a kit.
-Bill
Re: A/C recharging? [Re: Red_Chili] #455182 05/26/04 06:36 PM
G
Genshie Offline
Instead of re-charging I am gonna be re-moving and re-placing with a YORK to do the compressed air job. I already have it in there, but it is piggybacked off of the A/C compressor. Seen as though my A/C no longer works, it is mostly a trail rig, and the top is off 8 months out of the year...A/C is getting ripped out!
You are not going to see any significant gains in power with the AC gone, but maybe *a tiny bit*.
Kurt G.
Dented 85 4Runner courtesy of Wrecking Ball.
Re: A/C recharging? [Re: Genshie] #455183 05/26/04 06:37 PM
Red_Chili Offline
Hey, post a pic of your piggy-back. Erik Beebs did one, I'd like to see yours. I seem to recall there is a mini-York that might fit nicely.
-Bill
Re: A/C recharging? #455184 05/26/04 09:18 PM
Nah... I'm fully A/C certified/licensed... I won't waste my time with r134a on my personal vehicles... r134a work well in the newer vehicles and know all the systems quirks.
I'm licensed by IMACA for A/C and also ASE Master Certified. Not bragging but just want to make my point that I have been doing retrofits for 10 years now and I get the same A/C temps with R134 in an R12 system as if it had R12 still in there. There are little things that need taken care of to make this happen but it is cheap and easy.
My '90 Mazda 323 shop car blows 30* from the dash, my '84 Toyota truck used to blow 34* from the dash with a mechanical fan!! Now that it'll have an electric fan with the engine swap, I'm sure the temps will be even cooler.
Re: A/C recharging? #455185 05/26/04 09:46 PM
elripster Offline
The remarks about R134 not work as well in an R12 system are correct. However, there are ways to help it out. It doesn't.. without getting to engineer, carry the heat as well. (its enthalpy doesn't change as greatly with pressure as does R12) Running the higher pressures helps with this. I haven't tried this on the yota, but when the condenser went, my dad put a new condenser core from a newer model benz on his old 79 years back. When the evaporator core went, he again sought a larger one from a newer car. With some epoxy and plastic it was stuffed under the dash. The result was AC that functioned so close to original you couldn't tell.
Other things that help are finding ways to keep the air moving past the core when sitting still. Wiring up an electric fan for example is one way. If you have one, wire its realy in parallel with the temp sensor so it comes on with the AC compressor. That's probably getting deeper than most people to go but it's all about the heat transfer and moving more air through the core helps.
Frank
1994 4runner, 3.0, auto, 4.88's, 31's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos.
www.sdori.com
Post deleted by little_joe #455186 05/26/04 09:52 PM
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.494s Queries: 15 (0.009s) Memory: 0.6318 MB (Peak: 0.7394 MB) Data Comp: Off Server Time: 2026-11-04 20:49:51 UTC
